Question about Dell C600 (002UH) Motherboard
I found out that the ventilation fan of my Dell laptop is not working, so I want remove and check this fan. My problem is how to remove this fan.. Thanks if ever you have an idea..
  • 130 Answers
1st make sure that your warrenty has expired.
The unscrew ever visible screw on the reverse of the laptop.
there is a few hidden one there under stickers... You will see some more screws where your processor is, careful unscrew them, and your done. Was you cleaning your fan or replacing it?
Because your wire may have come loose connecting your CPU fan to the motherboard.
Best wishes.
-Tom.
Posted on Jul 14, 2009
Gateway nv59c66u
If it didn't overheated in the past, then your laptop might overheat because the ventilation system doesn't work properly anymore.
Check if the ventilation is blocked in any way. Just to be sure, blow some air through the cooling fan vent (on the left side of your laptop). If dust comes out, then continue doing so until there is no dust. Also, if your laptop had this condition for a long time, then you should replace the thermal paste or thermal pad on your processor because it might have dried out and it isn't efficient anymore.
Another reason would be a faulty component. For example, if your laptop overheats near the battery and the battery itself overheats, then the battery is the culprit and should be replaced or removed until a replacement is avaible (for example, this issue was common in Dell laptops rendering the battery useless after a short period of time).
Also, high work loads make laptop computers overheat. If you play a resource demanding game for a long time your laptop will overheat for sure.
For better feedback, describe when does your laptop overheats and where (as a whole or a certain area).
Jun 13, 2013 | Computers & Internet
Hit problam
1.Work with your laptop on a flat surface.I would recommend not to place the one on a bed as it will obstruct the fan from running properly and ventilating the heat.
1.Unplug your charger as soon as the battery is full
1.Clean the cooling fan exhaust system and also check fan is working properly or not.If fan is break down then repair it.
Aug 22, 2012 | Dell Inspiron 9300 Notebook
When the fan over heats it just shut down unexpectidly is it best just to buy a new fan or is there a way to solve this?
As you use your laptop, the CPU gets warm and the fan kicks in. If the CPU gets too hot, it will shut down as you have found.
Usually, the ventilation slots near to the CPU and CPU fan get clogged with fluff and dust. You need to clear this out.
Disconnect all power sources, turn the laptop upside down and remove any plate/covers that are easy to access.
Carefully blow/clear out any dust and fluff you can see, also try blowing into the ventilator slots. With luck this should clean it out well enough to keep your laptop running.
If not, you're getting into a dimantle scenario, taking more or less the whole thing apart and will neet CPU heat dispersal grease to re-assemble when clean.
Aug 21, 2010 | Computers & Internet
My Dell 610D runs for about 15 minutes getting progressively hotter(speed fan) and then just stops working?
It sounds like the DELL is overheating and shutting down and if it cannot start up again straight away until it has cooled down then it is definitely a thermal overload (overheating) problem.
If the fan is OK then the fault is most likely dust clogging the fan and heatsink assembly.
The fix - loosen the dust from the vents, fan and heatsink assembly and vacuum/remove the dust off these components.
Use the laptop on a flat hard surface and/or place small pads to increase the height and ventillation to the laptop.
If the problem persists then there are products such as fan assisted cooling pads that you place the laptop on to provide addition cooling to the laptop,
If you continue to ignore this problem then eventually the CPU chip will fail.
Dec 24, 2009 | Dell Latitude D600 Notebook
Therea are a lot of noise becouse the ventilator. El ventilador hace mucho ruido y se calienta,
If you have a Dell Latitude 410,(I didn't see it in your post , but it was at the top of the column) I found a user manual here: http://support.dell.com/support/edocs/systems/latd410/en/ug/index.htm But I believe from the looks of your post that might be Spanish, guia de usario: http://support.dell.com/support/edocs/systems/latd410/sp/index.htm The user guide said the fan only comes on when it needs to and some fan noise is normal. Laptops can get hot after extended use. Just be sure to give it plenty of room by the vents and make sure nothing becomes lodged in them. Dust bunnies, dirt and animal hair are known to cause problems. If you need to replace a part, check with Dell about your warranty.I hope this helps, and good luck. If I 'fixed ya' please rate me. Thanks.- jmattes
Oct 24, 2009 | Dell Latitude D410 Notebook
Wifi will not connect. Worked fine. Now the wifi light does not come on and it does not connect to the internet. No changes to the computer
The wireless switch is a type of switch which is located on the sides of the laptop. It is a type of sliding switch which looks like this.
Look for this and place it in on-position.
Dell has a software called Dell Utility in the Programs. Look for the same and look for Radio on /Off check box. Sometimes the radio tends to turn off automatically because of which you may not be able to connect to internet.
Sep 26, 2009 | Dell Inspiron 700M Notebook
Upper left hand corner of keyboard gets very hot and computer shuts down with no apparent reason, warning or error message
hELLO THERE:
WHAT YOU ARE GOING TO HAVE TO DO IS TO FLIP OVER THE LAPTOP AND REMOVE SEVERAL COVERS AND INSPECT FOR DUST I HAD TO DO THE SAME TO MY DELL / HP / GATEWAY, LAPTOPS AND ONCE I REMOVED ALL OF THE DUST AND DEBRIS THE LAPTOPS WORKED WELL ALSO DOUBLECHECK THE FAN AREA TO SEE IF THERE IS ANY DIRT AROUND THERE TOO OK?
BEST REGARDS MIKE
Aug 02, 2009 | Acer Aspire 3610 Notebook
Laptop Switches off and is really hot to touch
cooling fan not working.on the side of laptop see if the fan ventilation does not have dust covered.
Jun 29, 2009 | Dell Inspiron 5100 Notebook
Dell C600 (002UH) Motherboard Logo
134 people viewed this question
Clive
Clive
Alun Cox
