Question about PC Laptops
Behringer BCD3000 + Traktor 3 LE wont work on laptop
Hey guys, this one is a real doozy! Its not uncommon but very hard to fix as I have found out. I can get the combo to work fine on my desk top(which is well under the minimum requirements) but on my laptop, I can get the software running smooth (using built in sound card) but as soon as the BCD3000 is plugged in, and it made the primary sound card, it does nothing! Freezes up?
Before I updated the software, I had them working vaguely together but as I would start to play the 1st track, it would play for 10 seconds, pause for 5sec, play for 5 sec, pause for 5 sec etc.... Apparently the update had the "fix" in it but not for my lappy!
My lappy is running really well aside from all this. just had a full back ground service clean up so the thing is running like a dream, accept this compatibility-like issue.
Heres my specs:
  • ASUS A2500D
  • mobile AMD Athlon XP-D 2800+
  • 2.13GHz
  • 1 Gig RAM
  • 60Gig Hard Drive
Ive been trying to find out about updating motherboard drivers but Asus website is as helpful as a bee sting! Good luck guys, it would be great if you could figure out a solution. Kind Regards, Sam
  • 163 Answers
Re: Behringer BCD3000 + Traktor 3 LE wont work on laptop
Paralelling Digital audio.. Not a good Idea.. Im suprised you didnt kill the Modem/Sound chip in the laptop.. Glad you figured out however. Weve seen a ton of similar issues from People hooking an Analog Hi watt stereo to a digital out put laptop thru headphone jacks..Somthing going to give.. Always remember Modem and Sound on laptops are generally Integrated to the same circuitry..
Posted on Feb 15, 2008
0 characters
3 Points
My screen craked ! ugg and you guys wont fix it :/ how much would it be to fix it myself?
Google replacement screens for your computer and you will find several places that sell them and they are not that hard to install just have to be patient and very carefull, these screens break real easy.
Oct 04, 2011 | Acer Aspire One D255-2670
Hey my laptop, on start up says there is a there is an hard drive fault and failure is immentent and to back up data.... press F1 to continue.... this has happened for the past 1yr now it wont turn on at...
The error indicates that the Hard Drive in the computer has crashed and will require a replacement.
I made a quick search and found the part # of the HDD that was shipped with your model. It is
A1065524A. I would suggest that you replace the HDD with one with the same specification that was came with the computer.
You may either purchase it from Sony parts center or third party vendors.
Dec 13, 2010 | Sony VAIO PCG-V505CP Notebook
Toshiba laptop P100-ST9612 majors problems--NOT fixed by Toshiba.
oooo man that ones a doozy, if its the one with the go9700 video card its a pretty bad model. the card brand new is 700+ from toshiba. i have run into that problem quite a bit.
Nov 30, 2009 | Toshiba Satellite A105 Notebook
How to reset bios password on gateway model mx6650?
open ur pc cover and there r a cmos jumper on the near of the battery (cell). here 1 more pin on this jumper. remove the jumper and change the pin . than on ur pc for 10 - 20 sec and than off ur pc. and replace the jumper on his real place,,,,,,,
Sep 17, 2009 | Gateway MX6650 Intel Centrino Pentium M...
Problem with charging adapter on my laptop acer aspire 5335
the charger gets real hot??????? O really? wonder why?....Charger defect... guaranteed
Jun 27, 2009 | Acer Aspire 5335-2257 Notebook
Laptop wont power up
Hi guys,
does the power work when the ac charger power pack is connected and battery removed???
Jul 15, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
RE Traktor 3 + BCD3000
As the processor usage goes up to 100% I personally would check the fan on the processor. Does it seem to be running, does it speed up when the CPU goes to 100%.
I had this with graphics cards similar fault caused by the lubricant /grease on the fan spindle drying out and causing the fan to stick or stop, and then the graphics GPU getting too hot. Also check the heatsink / vents where the air from the fan blows out.
Just a thought.
Mar 17, 2008 | PC Laptops
Same problem
I fixed it!
The solution is very simple.
Just open the cover on the back, disconnect the CMOS battery. Then unplug the battery of laptop and power plug, let it rest for 20~40 minutes. This will allow the CMOS released.
Then, plug in the power. It works!
The only downside is the time and date on your computer will be set back. If you want to fix this minor problem, you need to buy a new CMOS battery. Also, because it was wired manually on the battery to hook it on. You need to hook wires on the button battery by yourself.
BTW: the BIOS update on HP website does NOT work.
I think HP knew what is the real cause for this problem, they just wont share it with us. This really pissed me off!
Even they changed a motherboard for you, it wont last longer than 2 years. Thus, the "free fix" wont solve this problem. Why dont they just public the method. It is just a minor thing, everybody with limited knowledge can fix it.
Who the hell want to change a laptop every 2 years with their own money? 3 or 4 years will be reasonable, 1 or 2 years? Jeez...
I will never ever buy a thing from HP again.
Mar 14, 2008 | HP Pavilion dv2000t Notebook
PC Laptops Logo
1,339 people viewed this question
Top PC Laptops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Laptop Expert? Answer questions, earn points and help others
