Problem for Krups Coffee and Espresso Makers
Generic problem for all Krups Coffee and Espresso Mak...
I would like instructions on how to use it ...
I would like instructions on how to use the fresh aroma coffee maker and grinder
Popular Solutions for Coffee and Espresso Makers
Krups Caffe Duomo 985-42 Espresso & Coffee Maker
1 Solution
Krups Small Appliances Coffee and Tea Appliances Espresso...
1 Solution
Krups XP7230 Compact Super Automatic Espresso Machine
1 Solution
Krups XP2070 Programmable Combination Machine; 10 cup Coffee...
1 Solution
Questions and Unsolved Problems for Coffee and Espresso Makers
which style of the bodum french press' is best, the chombard, brazil, or kenya?
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
When the coffee maker reaches temperature and the ''Coffee Ready'' light comes on, steam is...
(More)
When the coffee maker reaches temperature and the ''Coffee Ready'' light comes on, steam is discharged into the drip tray via the pressure relief valve and tube assembly. When coffee is made, the water quickly loses temperature and the ''Coffee Ready'' light goes out. I have recently descaled using an appropriate coffee machine descaler and the problem started thereafter. I suspect that a seal in the T-valve has failed, but I don't know why. I have dismantled the machine and inspected the boiler - the element is ok. What appears to be happening is that, as the water reaches temperature, the steam generated is forcing its way back along the pumped cold water supply line, across the T-valve and down the pressure relief tube. I guess the solution is to replace the T-valve, but why should the seals be damaged by the descaler? Is this likely to happen the next time I try to descale?
Hi, I have a Magimix expresso / filtre coffee machine, 15 bar, 2kw, about 3 years old. First the...
(More)
Hi, I have a Magimix expresso / filtre coffee machine, 15 bar, 2kw, about 3 years old. First the expresso coffee came out luke warm, now when I plug it in it trips the fusebox, any advice very much appreciated, many thanks, Jane
Model 169058 Where the carraffe sits is rusted. What do I do to clean it. It also does not keep the...
(More)
Model 169058 Where the carraffe sits is rusted. What do I do to clean it. It also does not keep the coffee hot anymore. Help
