Question about GE Dishwashers
Leaking at the bottom of a GE dishwasher
At the hinge where the door meets the base of the inside of the dishwasher, there is a seam made when the door is closed. At this point of closure, once the dishwasher was started; suds began pouring out from this base.
Please help!
Thank you! Deborah
  • 224 Answers
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Posted on Jul 11, 2009
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
Leaking from motor
Water Inlet Valve
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Seal
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
Dishwasher leaking from door hinges
Hello, your unit is leaking from the door hinges due to the inner seal on the inside of the tub that the door closes against needs to most likely be replaced if you have any further questions message me back Thanks
Rick
Sep 24, 2011 | KitchenAid Dishwashers
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
HDT 18PA 17 in. Haier Dishwasher... leaking at bottom of door. Need a new gasket. How do I order one and from whom do I order?
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 03, 2010 | Haier 17 in. HDT18PA Built-In Dishwasher
Kitchenaid dish washer kuds24sewh4 door leaks but does not seam to be gasket ! water drips from inside of door bottom? possibly rinse aid leaking in door?
remove the inner door panel and ck for leakage . there should be water tracks . / there is a bottom seal. that may be failing / ch to see if its in proper possion .. its on the tank under the door / open the door all the way and look from inside to see. ( with a light .. mm
Dec 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Leaking on LXIH dishwasher that is level
No. The water level is controlled by two probes inside the back RH corner of the tank. Level the unit with the smallest tilt backwards.
I would closely look at the wash (and rinse arms if equipped). Make sure there is no missing plugs (depends on how old unit is if plugs are used), and that there is no debris inside the wash arm. Debris will cause the water to spray off-line and hit the door seam directly.
Jun 18, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Leaking dishwasher
There are screws on the inside of the door on a lot of those try to tighten them down a little sometimes that can cause a leak.
Oct 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
210 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
