Model 110.82873120 won't spin on spin cycle - Washing Machines
  • 5,911 Answers
Check to make sure your lid switch is functioning. On your washer, the lid switch is located on the right hand side under the washer casing. As you lift the lid and close it, you should hear the switch clicking. If not, the switch may be broken, it may have come loose and is not making contact with the lid actuator, or the actuator itself may be broken. You can view a drawing of your lid swtich at searspartsdirect.com. Just look under the "Top and Cabinet" heading for item 11. The actuator (item 12) is what actually makes contact with the switch and toggles the push button. Make sure it is intact.
If the switch toggles, a resistance check with the power removed will tell you if the switch is still good. You should get 0 ohms with the push button closed (switch pushed in) and an open with the switch open (switch out). I'm trying to rule out the possibility of a bad timer by having you check the switch and actuator first. This is usually the more common fail item on top loaders experiencing a no spin problem. If you need to access the switch, you will need to remove the exterior case, by performing the steps outlined in the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
Your configuration may differ slightly from these instructions, but the assembly/disassembly of the washer casing should be the same. If you have any questions, or if your symptoms differ from what I have described here, please let me know so that I may assist you better. I hope this helps you.
Posted on Jul 11, 2009
  • Jeff Rockwell
    Jeff Rockwell Jul 19, 2009
My washer won't spin when its on rinse cycle
What is the complete model number of your unit?
Dec 05, 2012 | Kenmore 43142 Front Load Washer
My Hotpoint wf000 1000 spin model won't spin. It goes through a full wash cycle, agitates fine, but just won't spin at the end of the wash. Any help appreciated.
Sorry if it may be too obvious, but have you checked the philtre? generally they stop spinning when it's stuffed... when you open it, make sure you have a mop and bucket handy, some water will come out!
Nov 06, 2012 | Washing Machines
Washer won't drain, no spin cycle
What is the model number of your unit?
If you should need any further help, please visit http://appliancecafe.com/phpbb/ and register to login to the forum.
Oct 30, 2012 | Washing Machines
Won´t spin at all in any cycle
Goto http://www.frigidaire.com/manuals and download the model wiring diagram. It will explain how to view and interpret additional error codes. I have the exact same issue with my machine (will not spin). The error code #E47 indicates that the machine thinks the door is open and will not engage spin. Fixes: new door switch ($85) or new control board ($285).
Aug 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
235 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
