Question about Whirlpool Freezers
Whirlpool ED25TW - Water leak inside freezer
Water is leaking inside the freezer compartment. Ice maker will not fill up with water. Water dispenser works fine.
What is leaking and how do I find and repair it?
hotuna
  • 288 Answers
SOURCE: Ice Maker in door of freezer-ref combo.
The ice maker has a float or full detection device that shuts the water off when trays are full. If you are sure this is where the water is coming from, then that's it.
Posted on Dec 31, 2007
SOURCE: ice maker leaks into the ice storage bin
turn off the power to the appliance and apply a hairdryer to the ice maker compartment for about 2 mins , worked for me.
Posted on Jan 15, 2008
jaylex
  • 417 Answers
SOURCE: water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Posted on Feb 16, 2008
Kgt1962
  • 59 Answers
SOURCE: GE top freezer refrigerator automatic ice cube
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Posted on Mar 13, 2009
SOURCE: Freezer not freezing, and leaking
If this unit has an ice maker and you noticed water leaking into the refigerator, I had a similar problem. The water turn off valve for the ice maker had a small piece of sand or grit lodged in it and stopped the valve from closing properly. So it could not turn of completely and the valve became increasingly more sloppy as the piece of sand was wedged in further. The solution was to replace the samll valve. An easy job for someone a bit handy.
If the water has frozen in the bottom of the freezer compartment the colliing port for the cold air may also be affected. Don't chip the ice out of the bottom, defrost it with pans of hot water.
Hope this helps
Posted on May 03, 2009
Leaking a lot from water filter, which is inside and on roof of refrig.
Has the filter ever been frozen? that can cause it to crack. If not, it is probably going to be the filter head that has failed seals... Whirlpool Refrigerator Water Filter Housing WPW10238156
Mar 17, 2016 | Whirlpool WRF989SDAM 29 cu. ft. French...
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Whirlpool GS6NBE side by side ice maker works fine but the ice dispenser doesn't. I can hear a sound and a click when I push it and the dispenser flap works but no ice will come out. Water works fine.
The four prong (flat) plug to the ice maker (in the freezer compartment) in my Whirlpool Gold SbyS Refrigerator; should I be able to test for 120 Volts with a tester, should this plug be 'HOT"?
Sep 04, 2009 | Whirlpool Freezers
Ice maker not getting water
Probably the dual water valve (that opens when the ice maker needs water ) is leaking and the filling tube gets clogh with ice , or the valve doesn't work ,in both cases it has to be replace.
Aug 17, 2009 | Whirlpool Freezers
No water to ice maker. Water dispenser works fine.
The dual water valve is not working or is leaking and water freezes up in the ice maker filling tube and when it needs water won't go through.
Aug 13, 2009 | Frigidaire Freezers
Hope this helps
May 03, 2009 | Frigidaire Freezers
I have a Kenmore side/side with water dispenser and ice maker. Ice maker is not making ice, but I still get water. Every once in awhile I see a puddle under fridge (a large puddle). When I pull the fridge...
Hi TJ,
It'll cost around $65.00 to take care of this problem. The problem is the water inlet valve. The part number is 4389177 and can be picked up at your local appliance parts retailer or you can get one online maybe for a better price (just plug the part number into your favorite search engine).
Here's what's happening... The valve I mentioned is actually a "dual coil" unit. One coil supplies the cold water, the other feeds the ice maker. These "coils" are independant of each other, so one coil can fail and the other can keep on truckin', no problem. But what you have is an Ice Maker coil/valve that is weak and it's allowing water to bypass.
Basically the IM valve isn't closing shut completely. Imagine a dripping faucet... that's what it's like except you can't hear the drops, you can only see the results. Imagine drop by drop rising up that tube behind the fridge and into the IM. One drop at a time. These drops of water go into the freezer compartment through the IM fill tube. Now when these little ***** drops slide down the fill tube inside the freezer compartment they flash freeze before they reach the IM. One drop after another... drip drop drip drop. All these little droplets of water eventually form a glacier inside the fill tube.
OK, now we're at the point of glatiation. The fill tube (just behind the ice maker) has completely frozen solid. Now... when the IM "calls" for water to refill itself, the (failed) valve opens up and lets full pressure through. But where is this water/pressure going to go? The pressure builds inside the 1/4" water line until it can't handle it any more, the pressure looks for the path of least resistance. That path is the connection that you found loose. It blew out because the fill tube (into the freezer) is blocked with ice and the reason it's blocked is because the valve isn't shutting off completely.
That's alot of words to say this... it's an easy fix. Get the valve (above). Pull the fridge out. Unplug it. Turn the water off at the wall. Remove the water line going into the valve and set aside. Remove the cardboard panel. Remove the 2 screws holding the valve to the fridge. Pull the valve out. Note the electrical and tubing connections carefully. Get your new valve out and install the electrical and tubing just like the old one. Then rebuild, turn on the water and look for any leaks (use a flashlight and take a minute or two here... finding a leak now will save you alot of misery later). Replace the cardboard and plug it back in.
There ya go! Your first major appliance repair job done successfully? Priceless.
SG
Mar 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water dispenser / ice maker whirlpool fridge frezzer
thanks J
Jan 15, 2008 | Freezers
Freezers Logo
55 people viewed this question
Top Whirlpool Freezers Experts
AJMAL KHAN
Spencer Field
Spencer Field
Level 1 Expert
Steve Allison
Steve Allison
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
