Question about Kodak Easyshare C813 Digital Camera
Kodak cx 7525 Will not turn on when trying to take a picture. Brand new Kodak batteries.
    President:
  • 2,761 Answers
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
My cx 7530 just went blank when snapping a picture. New batteries etc. & will not turn on or off
look for the reset button . This is usually located at the bottom or back side of the camera. use a paper/hair clip to rest it. if still not working, look for a certified kodak tech.
Oct 23, 2010 | Kodak EasyShare CX7530 Digital Camera
The Camera will randomly turn itself off, batterie...
its better use Kodak battery for you Kodak camera.FYI there's a lot of brand of AA battery like energizer,duracel and also kodak.if you compare the size or the height of all battery its totally different.especially the kodak are more taller than the other.thats why if you use other brand it works only 5 shots only or less.
May 21, 2010 | Kodak EasyShare C875 Digital Camera
Digital Camera won't turn on
Check the contacts in the camera to be sure they are clean and free of any crusty white gunk. If so, scrape that stuff off. Try non rechargable batteries. It's possible that the recharables are dead.
Mar 14, 2009 | Kodak EasyShare CX7525 Digital Camera
CX 7525 won't charge on original dock
hi , the charging system is finish , now you have to buy some recharble battery, call that plan B
Nov 24, 2008 | Kodak EasyShare CX7525 Digital Camera
Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Jun 28, 2008 | Kodak EasyShare Z740 Digital Camera
Won't hold a charge
what rechargeable batteries are you using and what's your method of charging?
If your using a dock for charging - make sure you have the battery pack kodak kaa2hr otherwise the dock won't charge it
if you're using a separate charger - it's ok to use other AA ni-mh
please check the age of your batteries as well.. batts, even rechargeable eventually wear out - they can last up to 300 charging cycles and a year or a little more than that is enough for you consider buying a new set
if you say that you barely use the cam, batteries still deteriorate through time
Apr 12, 2008 | Kodak EasyShare CX7525 Digital Camera
Kodak CX7430 can only take 10 pictures with a new battery
Chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Mar 08, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Error #B03
UNFORTUNATELLY.....
Io sono un tecnico ed ho voluto APRIRE !!!
c'è un errore di progetto !!!
KODAK CI HA FREGATO!!!
esiste una batteria nascosat interna (quella che tiene la memoria foto ed impostazioni) che NON é sostituibile.
Quando questa si esaurisce la macchina può anche essere buttata, visto che il costo che dovremo subire per sostituirla tramite un centro specializzato è superiore a quello della macchina stessa: siamo vittime di una truffa !!!!
Stefano
Dec 23, 2007 | Kodak EasyShare CX7430 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
59 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
