Question about IBM (09N5424) Motherboard
Ram SUpport i HAVE A rEV 1.3 IBM motherboard and am wondering if it will support a ddr2 1 gig piece of Ram
  • 2,567 Answers
According to the specs of this motherboard, it only supports a maximum of 256 MB of SDRAM. So, it definitely does not support 1 GB DDR2 memory modules.
Posted on Jul 11, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I have a ibm rev 1.6 and I would like to know if I can put 1 gb of ram in it?
You would need to tell us what the motherboard model number is.
Apr 05, 2013 | Computers & Internet
Ram compatibilty
Yes you can but the higher spec DDR2/800 RAM will run at at lower speed same as the DDR2/ 667 RAM.
When you install the DDR2/800 RAM and the BIOS only detects 1Gb of RAM then this RAM is not compatible with the 1st RAM module. In this case use RAM module that is the same make and speed as the original RAM module.
May 03, 2012 | Computers & Internet
Hi, i used to have 1 gig ram . recently i bought 2 gig ram both has 667 Mhz of speed the prob is that pc is not booting up with 2 gig in combo or alone is it problem with the bios please help
Hi
This is DDR2 RAM for a motherboard that takes DDR2 RAM.
It is more likely that the RAM is incompatible. Check the correct RAM specification range for *********** board.
Also some RAM is Error Correcting and this might not be compatible with your motherboard. Most PC motherboards take non error correcting RAM.
If not, the RAM may be faulty. Most RAM has a lifetime warranty, so you should be able to return it.
To clear the BIOS memory, disconnect the power cable and remove the small silver CMOS battery for 2 ninutes, then reintstall the battery, reconnect th epower and test again.
I hope this helps.
Aug 26, 2011 | Computers & Internet
PCI Simple Communications Controller, seem not to function
Hello my friend
First your motherboard does not support windows 7 and the maximum ram capacity is 4GB DDR400/333/266 non-ECC DDR SDRAM memory
Second you can go here and check which memory your motherboard supports
P4P800 SE Memory QV
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/P4P800_SE_QVL.pdf
Third you can try updating your Bios,more information in your manual
MANUAL
http://dlsvr.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
your motherboard details is here
http://www.asus.com/product.aspx?P_ID=YNlDkmz5gSNpiCr6&templete=2
Good luck
Jan 14, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Ram issue - GA-8VM800PMD-775
This Type Mother Board Comes With DDR2 RAM.
Go to the Nearer Computer Pheripheral Store Ask for 1 GB or 512 DDR2 RAM..there are several brands Simmtronics,Hynix,Transcend. You can get u r choice.
Jul 08, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
Can I add 2 One gig ram sticks to a IBM Rev 1.2 motherboard? It has this number FRU PN 49P1599
try to look at your manual if it is compatible in you motherboard then make sure that the RAM the you buy is the same speed in your old RAM.. ^^
Jan 29, 2009 | IBM (25P3294) Motherboard
FOR IBM MOTHERBOARD REV 1.6
I believe the fastest CPU you can install in that motherboard is a Athlon XP 3200+ (2.2GHZ) socket 7 CPU.
That board uses eaither DDR 1 or SD-RAM and is definatly not compatible with DDR2 which uses a different connector on the motherboard (more pins)
Jan 21, 2009 | IBM (09N5424) Motherboard
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
DDR2 533Mhz 2 x 1GB
the DDR IS THE RAM , the processor and the ram and a good motherboard work and produce a beep,
remove the processor and the ram, get other working processor and the ram and try on your system, it works troubleshoot the removed processor and ram to find out the bad one and it does not work, your motherboard is dead.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 12, 2008 | EliteGroup P4M800PRO-M Motherboard
Ram upgrade
In order to see how many MHz is your desktop, please right click on your "My computer" icon and select "Properties" from the menu.
It will open the system properties window. select the tab "general" and you will see how many MHz is your desktop.
If you have found this solution helpful please rate it as "solved", otherwise please ask here again.
Thank you :)
Oct 12, 2007 | Computers & Internet
IBM (09N5424) Motherboard Logo
418 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
