Question about Kicker CVR12 Car Subwoofer
My wire got pulled off my sub how can i fix it
  • 655 Answers
Hello gatmanfromda,
I'm assuming you mean the "tinsel" lead going from the connector to the sub cone. In many cases, the wire can be soldered back on. It takes care and patience and you need to be sparing with the solder and prevent it from stiffening the tinsel lead. Otherwise it will tear out again when the sub cones moves out. If the cone itself was damaged when the lead pulled off, you can use silicone sealant to repair it. Again, be sparing with the silicone and allow it 24 hours to set up before trying to operate the sub. If the wire pulled off from the connector terminal, just solder it back on.
Hope this helps.
Posted on Jul 11, 2009
Mackie 15 inch replacement speaker
To determine polarity of a sub, take a 9 volt battery and two one foot pieces of wire. Connect each wire to each terminal on the sub. Then touch one wire to one side of the 9 volt battery terminal and the other wire to the other side terminal. If the subs cone pushes upwards that is the correct way to hook it up(in phase which is normal). If the subs cone pulls down, is is 180 degrees out of phase. I hope that this answers your question.
Jan 14, 2014 | Insignia Car Audio & Video
I have a Sub-Zero 501 F upright freezer. I have never hooked up the ice-cube maker. There is a problem with ice build up in the drain tray and it overflows into the ice-maker. I had a tech in and he put...
sounds like the mullion heater (drain tube heater is open). take back off (after removing all shelves, including the glass tray (remove 4 screws). Pull back out, careful not to pull wires off T'stat. Run the new wires on heater behind evaperator, placing heater down in drain hole. Good Luck
Joe
Aug 09, 2010 | Sub-Zero Freezers
12 year old sub-zero refer-the ice maker drawer will not open. Something will not allow the drawer to be pulled open.
There is a plastic sled that fits on a wire bail, connected to a microswitch that tells the unit that the ice level is low and it needs to turn on the water to fill the ice cube trays. The wire bail falls out and catches on the drawer. If you pull too hard, you will break the plastic sled where it attaches to the bail. You can still buy the entire ice maker unit and re-install it easily, or if you are really handy, you can attempt a temporary fix with a little bit of wire at each end of the plasitc sled to keep it attached correctly to the wire bail. The older units were famous for this problem. I fixed mine, but ultimately had to replace the unit. Parts cost around $130.
Jan 04, 2010 | Sub-Zero 561 / F
What do you do when the wires to the sub are pulled out??? and the wires arent showing and you cant soter them back on?? my bro was moving it into his car and it slipped out of his hands as he was putting...
Its ok, no biggie. So you are saying that there is no bare wire showing? All you have to do is take a razor, and lightly apply pressure on the wire to create a line on the wire so you can pull off the cover and re-soldier. Just do this about half an inch to an inch from the tip of the wire. Its not hard, i've been doing it since I was 4.
Oct 08, 2009 | Infinity KAPPA 120.3DVC Car Subwoofer
I recently was trying to install a 10 inch pa sub with a 3/6 inch tweeter and in the process snipped the black and red wires connected the sub it did not come on I then snipped the blue and red wires in...
sounds like you blew some fuses replace them. then reconnect stock wiring. the get after market deck, amp, and wiring that in it's color coded so it no that hard to do.that 10 inch pa speaker pulls a lot power plus it 8 ohm impudence. your going to need at least a 200 watt amp.bridgeable.
or single channel.
Sep 20, 2009 | 1995 Ford Escort
My subwoofers ''fight'' each other
YOU ARE CONECTING ONE OF THE SUBS ON THE INCORRECT MODE SO DISCONNECT ONE OF THE SUBS AND SWAP THE WIRES AND TRY.
Mar 23, 2009 | Car Audio & Video
Punch p1 10" not working
I had the same issue with 2 Punch p1's. The wire stripping was most likely cut where the wires are saddled against 2 bare metal "C" shaped tabs before going toward the cone and coil. This was causing the wire to ground out. I cut both wires and **** connected them and bypassed the factory bracket. They work fine now. This is a poor desogn from Rockford and I can see where it might happen numerous times.
May 20, 2008 | Rockford Fosgate Punch Stage P110 S4 Car...
Kicker CVR12 Car Subwoofer Logo
804 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
