Question about Ryobi Three Trimmer Combo
Ryobi 31cc , 17inch weed ,hard to start ,needs to stay choked to
Ryobi 31cc , weedeater, hard to start ,needs to stay choked to run sometimes will not excelerate
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 108 Answers
I got on here to find the solution for the same problem. This seems to be fairly common. I need to have it at 3/4 choke to run properly. Other posts say the exact same thing, about the 3/4 choke. It is apparenly something that breaks occationally.
I'm going to remove the carb and take it apart. My suspection is the diaphram in the bottom of the carb. There isn't much you can do with the carb, it is very simple and has few parts.
There is a chance that it is a blocked passageway also.
There are instructions for adjusting the mixture, but they are not clear enough. I will be posting a clarification reqest on one of those posts. Will also post again after I check the diaphram.
Posted on Aug 04, 2009
The 700r? yes just spent 2hrs on this one today and might have come to 2 possibles #1st check the right spark plug and the magneto gap re; flywheel? 2nd the filter in the carb restricting flow looks cheap.
Posted on Apr 15, 2010
Just found the fix for our 31cc 17'' Ryobi and its not wanting to run, sometimes not wanting to start. Also this fix took care of the air in the primer line.
Turned out that it was the cylinder head to crankcase bolts had backed out. The visual "telltale" was the head gasket was waving at me. This causes an abundance of air to goof things up.
If you ever need to find out if there is a leak similar to this, spray some started fluid around the base of the carburetor or the head. If the engine starts screaming RPM's, you found a likely area to investigate.
It took a 30T Torx tip and a 6'' Cresent wrench to get them tightened down... for the time being anyhow. While you are tightening things, check the muffler and the choke assembly screw. Both mine were loose.
I have had this same thing happen with a SkiDoo Elan snow machine, a couple of different makes of chain saws and now this Ryobi.
As long as I am here please check out www.litedriver.com
Posted on May 02, 2010
  • dmhandyman Jul 25, 2014
    Keep in mind that starter fuild is explosive. Spraying it on a running motor can cause a fire or explosion.
  • Ken Wells Jul 25, 2014
    Giving starter fluid to an engine is never good. Use only premium NON-ethanol gas. Here, we can only get in Premium or go to a marina for gas. Do not use off the shelf ethanol remover. Only additive I use is Sta-Bil. Do this gas and I guarantee in a minute you wacker will hum.
How to start a Ryobi s430 4 cycle weedeater?
I have a husky 4 cycle I have to choke it and it is a bulgar to start once I get it running it runs like a champ just make sure you check your oil first
Oct 10, 2017 | Ryobi Garden
Bought new e3 plugs for weedeaters and cant find gaps for them i have a Featherlite 20cc Fl20 and a Ryobi 31cc 700R
The gap for the Weed Eater 20cc engine can be set @ .025". The larger engine Ryobi 31cc/32cc class can be set @ .030" Either engine would operate within that .005" range and I know a 32cc Poulan calls for a .030" gap.
Jul 09, 2010 | Garden
Ryobi weedeater 4 stroke starts but only runs for a second or so I can get it to run but not well and I have to have some choke on to do it
We have a Ryobi gas weed eater. We can get it started but it doesn't stay on. I took it in to get it fixed and he said it was the primer switch, which he replaced, but we are still having the same problem.
Can you help us or refer us to a Ryobi repair store? We live in Phoenix, Arizona but can go to any repair store in Glendale, Tempe, Phoenix, Mesa, Scottsdale, wherever in Arizona. Thank you. Sally
Jun 02, 2010 | Ryobi Garden
RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Aug 01, 2009 | Ryobi Garden
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
31cc Ryobi weed eater engine will start, then stall shortly after
you need to adjust the carb ,look for small screws around carb turn out 1/4 to 1/2 turn good luck
May 24, 2009 | Black & Decker 19" Electric Lawnhog...
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Ryobi Three Trimmer Combo  Logo
2,281 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Gene Tuck
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
