Question about Husqvarna Designer I
Fix button won't work in embroidery mode
"fix" button won't work in embroidery mode :(
  • rfnewell Jul 11, 2009
    Designer 1 "Fix" button wont' work in embroidery mode.
  • 201 Answers
Just to make sure you know what "Fix" does in Embroidery Mode - you press it before you start your embroidery then when you press Start, the machine will baste a square or rectangle the size of your embroidery before moving back to the centre ready to start the actual embroidery. It is not used to Fix stitches in embroidery mode (like it does in regular sewing mode) and it must be used before the embroidery is begun if you want the basting. Is this problem you have? It will not do the baste stitch?
Posted on Jul 24, 2009
Artista 165 embroidery unit will not communicate with my sewing machine.
Did it ever work ? Have you had the firmware updated in the machine - if-so, the V4.04 firmware will not communicate with a V3 embroidery unit and you'll have to get them updated to the same version. Failing that, I'm afraid one of them has a fault on the serial interface. Note also that a 165 sewing machine will not work with a 180/185 embroidery unit because the earlier unit has a 2MB memory internally, whereas the later unit has a plug-in 4MB memory.
Feb 09, 2012 | Bernina Artista 180
My babylock ellure won't work on the embroidery mode, but works on the sewing mode. I only use this machine for embroidery. When I turn it on it tells me to lift the pressor foot, which I do, but nothing...
Ours did the same thing. They said it was the circuit board for embroidery that went bad. The one for sewing is still good. They wanted $200 to $300 to replace it.
Oct 19, 2010 | Baby Lock Ellure
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Oct 27, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Fabric doesn't Feed
I have a Janome, and when switching from embroidery back to sewing, I must touch a button that electronically moves the mode from embroidery to sewing. In some cases, I've also had to turn off the machine for a few minutes and then turn it on again.
I used to own a Viking - it had a little door covering the attachment link for the embroidery arm. If it wasn't perfectly shut, the machine wouldn't convert to sewing mode, regardless of what button I pushed.
Nov 19, 2006 | Bernina Activa 130
Sewing Machines Logo
212 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
MissFixIt828
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
