Question about Craftsman Convertible 25cc. Gas Line Trimmer
CRAFTSMAN WEED WACKER WHAT IS PROPER FUEL LINE ROUTING ? Replaced fuel tank and fuel lines now it will not start does someone know the proper routing of lines?
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: 17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Posted on Sep 19, 2011
Fuel line routing for craftsman chainsaw 358.350370
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 11, 2012 | Garden
Hi pmbaugardne...
Sep 19, 2011 | Craftsman Garden
Model no.358791072 fuel lines were rotted.I need a diagram of the proper order
Hi and welcome to FixYa, I am Kelly.
The fuel line WITHOUT a strainer will go from the tank to the OUTSIDE primber bulb connection then from the primer bulb center connection to the carb. Item 7 this link comes with the diagrams:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358791072/0247/1503820/P0808034/00002?blt=06&prst=0&shdMod=358791072
There are several you tube videos here on replacing fuel lines:
Something to note... inside the tank there is a fuel filter/strainer. Make sure to replace that fuel line also. The connection from the strainer will connect straight to the carb fuel mainfold connection. The center connection of the primer bulb will go straight to the carb fuel manifold.
http://www.fixya.com/uploads/images/1CE2BC8.gif (Expand to 200%)
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Craftsman 25cc Gas Line Trimmer
ON OF THE GAS LINE BROKEN INSIDE TANK.. IT **** AIR.. HOW DO I KNOW WHERE IT GOES..
Try the SEARCH feature on this site. MANY posts have been made about fuel line routing for this and other models (tey are basically all the same). Search for : Weed Eater Fuel Line or Weed Eater Fuel Line Routing. It is there because I have been there and seen it.
Aug 10, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Craftsman Brush Wacker routing of fuel lines Model 358-795200 Was laying in bottom of top mount gas tank
Use new fuel line. There should be two things (besides fuel line) in the fuel tank. The small line has a (1) fuel filter attached and is routed to the lower outlet on the carb. This is the fuel supply line. Make sure there are a few inches of it inside the tank. (say enough to reach other side of tank). The larger line should have a (2) nylon connector inside the tank holding it. The connector stays right at the tank hole. That larger line goes to the closest outlet on the purge bulb. The other fitting on the purge bulb should have a larger line that connects to the upper fitting on the carb.
Feed enough length of fuel line thru tank holes to pull them out where cap is to put on the filter and nylon connector...then pull them back thru. WD-40 will aid in this procedure or any light oil.
Jun 10, 2010 | Craftsman Garden
Fuel line crack dry out, in pieces
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Find your saw here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
I think the second line on the carburetor is an impulse line and connects to the crank case. HTH
Lou
Oct 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Apr 04, 2009 | Garden
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Convertible 25cc. Gas Line Trimmer Logo
2,998 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
john h
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
