Question about Maytag Dryers
Maytag MD-24 does not heat, all breakers are on, lint filters clean and no out let restriction. Captain paul
2 Suggested Answers
  • 13 Answers
SOURCE: I have a Maytag Gas Dryer # LDG9606AAE, No Heat
There is a thermal fuse located on the back of the blower housing. Part # 306604.
Posted on Jul 31, 2009
Dryer is taking a longer time than normal to dry unless we switch it to timer. Replace sensors?
  • Remove and clean the lint filter each time it is used. The filter can be washed with warm soapy water to remove fabric softener residue from the screen.
  • Check the household fuses and circuit breakers. Most household dryers use two fuses or circuit breakers. It is possible for only one of them to trip and the dryer still tumble, but not heat.
  • The washer controls may have been improperly set. If the clothes are wetter than normal, coming from the washer, this could be the difficulty. If the gentle speed is selected for a normal load the washer will not spin adequately. High speed or extended spin removes more water from clothing decreasing drying time
A lint filter that is full of lint will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder after each and every use. Check the lint filter for any buildup of fabric softener that will restrict airflow and wash with soapy water to clean. If the filter is damaged then replace it.
Nov 09, 2017 | Dryers
Dryer is not heating and it says check filter. What does that mean?
there is a lint filter that needs cleaned . usually every time you use the machine check this link LG D1102W Owner Manual Page 35
Apr 06, 2015 | LG DLG5002W 27" Gas Dryer
Why is my maytag dryer running for a long time but not getting my clothes dry, and the vent pipe its clean?
I note the vent is clean.... Now start checking for heat from that vent with the dryer on. You did not mention the model number so we at FixYa do not know if this is a gas or electric dryer. If it is electric cycle the circuit breaker to off (PUSH hard to OFF) then back on. There is a chance that only 1 breaker is connected. It would run and not heat.
Also the airflow out the back of the dryer should gently push a relaxed hand / wrist away from the vent outlet. If it does not do this you have an airflow problem. Look inside the dryer vent outlet for any signs of lint build up. You can have a clean vent but a blocked dryer vent inside the dryer. Go outside the house and check the thru the wall vent hood and flapper for lint buildup. This is a VERY common airflow restriction point. check BOTH sides of the metal flapper for lint. Lastly if after all of this you still have airflow problems the blower wheel hub can be broken or lint on the blower wheel.
Pull the lint filter and wash the filter with vinegar and water then soap and water. Fabric sheet particulate can cause restricted airflow. Also take a flashlight and look hard around the lint filter area for lint build up. Use a folded metal coat hanger to assist in lint removal along with a vacuum and crevice tool.
If you do not have heat... at all... after all of this; please respond with a model number so we can sort out where to go next in troubleshooting.
Thanks for choosing FiXya.
Kelly
Sep 08, 2010 | Maytag Dryers
My dryer won't heat. Maytag DE410
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day. Rating the solution is highly appreciated.
Jul 03, 2010 | Maytag Dryers
Mdg2600bww is not ignighting, cleared ventline, turns on, just no heat
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Jul 02, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My maytag front load dryer turns on and runs,it does not blow any hot air
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Will not get hot
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker. Make sure that the lint filter and exhaust duct is clean.
Another common cause of a dryer failing to heat is a faulty heating element. You will need to replace it.
Jun 30, 2010 | Maytag SDE3606A Electric Dryer
My old Maytag DE307 dryer gets hot right away, then after about 2 minutes or less, stops blowing hot and goes to warm. Let it cool down,and the cycle repeats.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This is generally an airflow issue. Restricted airflow will cause the hi-limit thermal protector to open and turn off the heat in order to prevent a lint fire, or fabric melt issue. Remove the exhaust vent from the dryer and ascertain that there are no obstruction/restriction to the vent hood, Include the vent hood in your inspection to make sure it has not been crushed or damaged. Make sure your lint filter is cleaned after each load. Do not use fabric sheets as this will place an invisible coating on the lint filter that restricts airflow, (Replace filter). Do not overload the dryer. If your washer is newer, then larger loads are capable of overloading the dryer.
A blower malfunction or worn belts could cause lower airflow issues. Replace if worn.
Visit; www.repairclinic.com, for complete DIY instructions, disassembly procedures, and repair parts list.
Hope this helps.
Jul 12, 2009 | Maytag Dryers
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune Model #MDG6800Aww
Hi!! You seem to have a problem with your heating element on the dryer..Also make sure that your breaker going into your dryer is on..Good luck..
Jan 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
303 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
