Question about Microsoft Windows XP Professional SP2
When ever my system starts icant get any taskbar or desktopitems
And even my taskmanager is also disabled i have to access my sys using utility manager
  • 37 Answers
Hi !!
If you are experiencing low performance and your task manager is also disabled then most probably your computer is infected by a virus. Update your antivirus and run complete scan. If you are not using any malware or spyware i'll recommend you to install malwarebytes you can download free version from malwarebytes.org and also install good spyware. Hope that helps
Thanks
Posted on Jul 11, 2009
Screen responding verysliw
Is it computer or just the screen that is slow? First confirm if display driver is installed by going to control panel => system => device manager (might vary depending upon the operating system you are having). Also try to install monitor driver if you have. Right click desktop => click properties => settings => advanced => monitor. Here you can change frequency. Set it to lower settings like 50 or 60 Hz depending on your system. See if any program that has wrong settings especially softwares like video editing softwares. For example https://youtu.be/lOT4zLqMOWQ
Right click on taskbar and open taskmanager and see which application is utilizing more CPU or memory resource. If anything is abnormally utilizing excess system resources right click that application and select end task to see if that solves slow responding problem.
Dec 19, 2017 | Computers & Internet
Tip
Steps to Delete Files Used by another Program in windows
Hi,<br />Follow these steps to delete any files used by another program.<br />1. Right click the windows taskbar and open taskmanager.<br />2. Kill explorer.exe from the taskmanager.<br />3.Click file-&gt;open new task from the taskmanager window.<br />4. Type cmd.exe in the box and command window will come.<br />5. Go the directory of the file to be removed.<br />6. Delete the file using following command<br /> del fileName<br /><br />
on Jan 05, 2011 | Computers & Internet
I would like to display the date also at the right bottom corner of my computer. The time is already displayed there.
Which operating system do you have ?
The Window's taskbar organizes open and running programs, provides a quick way to access application shortcuts, and gives easy to access to important computer functions and utilities via the system tray. Most users of Windows center their workflow around the Window's task bar for its convenience and ease of use. With the clock function automatically enabled, users can add the date to their task bar while increasing the space for more application shortcuts.
Add The Date To The Taskbar In Windows XP/Vista Right-click on your Window's taskbar and click "Lock the taskbar" option to remove the check mark next to it and unlock your taskbar. If there is no check mark next to it, do not click it as your taskbar is already unlocked. Move your cursor to the top edge of the Start menu and wait for it to change into a double arrow. Click and hold the left mouse button and drag your mouse upwards until the taskbar physically changes in . When it does, it will add the day and the date under the time. Add The Date To The Taskbar In Windows 7 Right-click on the Window's taskbar and select "Properties" from the resulting menu. Click the check box next to "Use Small Icons" to disable the option. The icons will get slightly larger and the date will appear under the time. Click "Apply" followed by "Ok" to save your changes and exit the window.
Mar 15, 2013 | Dell Computers & Internet
THE TASKMANAGER'S PERFORMANCE SHOWS 100% USAGE EVEN WHEN THE COMPUTER IS NOT PERFORMING ANY TASK.SPEED OF THE COMPUTER HAS BECOME VERY SLOW.
Start by identifying the processes which are using the cpu and stop them or disable the processes which are causing the usage.
Mar 07, 2011 | Computers & Internet
How to enable control panael,taskmanager
Method 1 - Using the Group Policy Editor in Windows XP Professional
  1. Click Start, Run, type gpedit.msc and click OK.
  2. Under User Configuration, Click on the plus (+) next to Administrative Templates
  3. Click on the plus (+) next tSystem, then click on Ctrl+Alt+Delete Options
  4. Find Remove Task Manager in the right-hand pane and double click on it
  5. Choose the option "Not Configured" and click Ok.
  6. Close the Group Policy Window
Method 2: Change the Task Manager Option through the Run line
  1. Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 3: Change Task Manager through a Registry REG file
  1. Click on Start, Run, and type Notepad and press Enter
  2. Copy and paste the information between the dotted lines into Notepad and save it to your desktop as taskmanager.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
3. Double click on the taskmanager.reg file to enter the information into the Windows registry
Method 4: Delete the restriction in the registry manually
  1. Click on Start, Run, and type REGEDIT and press Enter
  2. Navigate to the following branch
    HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  3. In the right pane, find and delete the value named DisableTaskMgr
  4. Close the registry editor
For Control Panel
Start | Run | Type: gpedit.msc | OK |
Navigate to >>>
User Configuration\Administrative Templates\Control Panel\
Prohibit access to the Control Panel
[[Disables all Control Panel programs.]]
Jan 12, 2010 | Microsoft Windows XP Home Edition
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Endtask option disabled
try going to the registry hive and change the value that is stated below.
Type: REG_DWORD
restart the PC if the changes didn't take effect immediately.
Feb 04, 2009 | Microsoft Windows XP Professional With...
Taskmanager
If you have access to a clean computer with a burner, then download Hirens Boot Disc.
The download is only around 80-90 meg and can be burnt onto a cd or dvd.
Download HERE.
Burn that program to cd and put it into the infected PC. Start the computer up and boot from the CD instead of the hard drive.
There are anti virus utilities on there that run in Dos mode without ever loading anything from your hard drive.
May 05, 2008 | Microsoft Windows XP Professional
Taskmanager & regedit
When you press Ctrl + alt +delete, the task manager does not appear? Try right clicking on your desktop tool bar and clicking task manager: For regedit click Start > run and type regedit
Mar 26, 2008 | Microsoft Windows XP Professional for PC
My task manger is disabled by the administrator
For Windows XP Home Edition use "The registry edit & For Windows XP Professional you still use the option I had suggested which is:
• Click Start
• Click Run
o Select User Configuration
o Select Administrative Templates
o Select System
o Select Ctrl+Alt+Delete options
o Select Remove Task Manager
o Double-click the Remove Task Manager option
I hope this Info has helped you.
or:
Click Start -> Run. Type in "regedit" (no quotes) and hit Enter.
Search for HKEY_CURRENT_USER -> Software \ Microsoft \ Windows \ CurrentVersion \ Policies \ System.
Look for: DisableTaskMgr. Click on REG_DWORD. Value: 1=Enable this key (disables TaskManager); Value: 0=Disable (actually enables TaskManager)
Close RegEdit
Reboot your machine.
Oct 17, 2007 | Sony VAIO Digital Studio PCV-RZ22G PC...
Microsoft Windows XP Professional SP2 Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
