SOURCE: technics sl-b303
Try this company for help?
service<remove>@turntableneedles.com
they have a help line and may be able to assist you?
Note; take the <remove> bit from the link to email them?
SOURCE: Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
SOURCE: I have just bought a
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
SOURCE: my deck plays too fast and i must adjust pitch
this is calibrated from factory, the control board is faling check for any pot. If available, adjust a little the speed pot
Thank you every one for the answers, I managed to fix it by pulling off the bottom and adjusting the pitch screw.
