Question about HP LaserJet 4000n Printer
I have a Hp Laserjet 4000n printer. Whenever i try to print the paper is printed but it does not come out and is jammed under the catridge and it displays error 13.5 all the time. can someone please help me figure out.
    President:
  • 3,085 Answers
It sounds like the fuser roller is not turning.
Remove two small caps, unscrew the fuser fuser and remove it.
Rough up the red roller with Scotch Brite
Oil the black bearings on the top roller.
Posted on Jul 11, 2009
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
How to change from tray 1 printing to main tray 2 on hp 4000 printer
On the printer drivers, if you go to the settings, you can change the default. It should be under a setting called paper.
thanks adi
Feb 23, 2010 | HP LaserJet 4000n Printer
Printer is not at all taking the paper to print
Pull open the front of the printer
remove the toner cart
clean the gray rubber roller with alcohol
Feb 01, 2009 | HP LaserJet 1100 Printer
HP laserjet 5000N - Paper jam under the cartridge every time try to print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | HP LaserJet 5000n Printer
HP LaserJet 5000n - Paper jam under the cartridge
Check the tray to make sure the paper stops are set right and that the printer is set for the correct size paper. Clean the feed rollers above the paper in the tray and if necessary, replace them.
Printing problem
The printer itself is printing, but when I stalled Laserjet 4000 and try to print it shows ERROR even printing test page. I do not know why my HP laptop Vista cann't recognize the printer!
Thanks,
Iyaad09
Nov 23, 2008 | HP LaserJet 4000n Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Feb 20, 2008 | HP LaserJet 2420 Printer
Can't get it to print
plese select its paper size and also check the paper sensor
Sep 19, 2007 | HP LaserJet 4000n Printer
HP LaserJet 4000n Printer Logo
113 people viewed this question
Clive
Clive
