Question about Advueu Technology AMW-F176B Monitor
Amw monitor blinks with a blue power light
But will not power up...any suggestions? I have another one bought on the same day and have had no problems. HELP!
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 11, 2009
Monitor goes off and on by itself
Hello bjaykaye,
The problems you are having are an indication of a Power Supply problem. The issue could be in the switching power supply or the High Voltage Power Supply. The shutdown circuit is activating which is allowing the TV to play until it detects an over-current event. When an over-current event happens the shutdown circuit will turn the TV off. I would suggest that you check the Horizontal Output Transistor, the HV Transformer, the Horizontal damper diode, and the capacitors that are in parallel to the damper diode. The important thing is to find the component that is causing the problem. If you do not have a background in electronics I would suggest that you get a qualified electronics technician to look at the set.
Thank you,
Shuttle83
Oct 29, 2007 | InFocus ScreenPlay 61" Rear Projection...
I have a gateway FPD1975W monitor with a Gateway GT5482E computer. The monitor does not display the computer output - the blue power light blinks off and on steadily and every so often the monitor says...
From your description you have a power supply problem, usually caused by defective capacitors, sometimes they will bulge at the top indicating an open condition. If you decide to repair check the inverter board that powers the back lights behind the screen, because they are also prone to bad caps.
Feb 17, 2011 | Gateway FPD1975 19" LCD Monitor
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
AMW model MW19E-bcd doesn't come on
stepstve, You will find some vid clips on monitor tear-down at YouTube if u search under LCD repair and or bad capacitors. Is this monitor one that has a "lay on floor" brick power supply, or does monitor plug directly into wall outlet? If you open monitor look for capacitors with swollen tops of their aluminum can housings. Take pictures or video of what u do!!!! Just so u can put it back together with no leftover parts!!!! Have a friend help you. How old is monitor? Also search under "cold cathode fluorescent tubes" for information on how they operate.
you should also understand some basics of "switch-mode-power-supplies" and how they operate. Bye for now. lmistyrel @ aol.com
Sep 15, 2009 | Advueu Technology AMW-F196B
AMW 199B monitor takes forever to come on
My AMW 199B shuts down.On button shows no light.If push on button nothing happens.So I unplug it and it will come and stay on for a long time,(last time a day), then all of a sudden it will shut down
Aug 04, 2009 | Advueu Technology AMW-F196B
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
6 mo old amw monitor A913B 19
Same Monitor, same problem. Solution: I changed the colors setting to 16 bit from 32 bit, and that cleared the problem. I then changed back to 32 bit and it still worked. How long, not known yet. So , go to display settings, find COLORS: and then change to 16 bit.
Jun 23, 2008 | Computers & Internet
Advueu Technology AMW-F176B Monitor Logo
556 people viewed this question
Top Advueu Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
