Question about Refrigerators
No air getting to fridge, freezer barely freezing
    Champion:
  • 363 Answers
Sounds like the circulating fan behind the rear panel of the freezer is wearing out. When the freezer/refrigerator fan starts to wear out the rpms reduce to a point where it will keep the freezer cold but not the frig. the total minimum estimated cost to repair this problem is around $300.00 parts and labor
Posted on Jul 26, 2009
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
FDF-358 freezer is taking a couple of days to freeze solid and the fridge is just barely keeping anything cold ..... fan in the freezer is not iced over, there is no feel of cold air when you open the...
Refrigerant may need re-gassing, needing fridge-tech.
Thermostat may be set too warm, turn colder.
Door seal may be warped, allowing warm air in. check with door closed.
Sep 30, 2017 | Daewoo Refrigerators
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
Refrigerator side is barely cool but the freezer side is freezing properly. Thermostat is turned up to "9"
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 19, 2009 | Refrigerators
Fridge barely cool freezer not freezing
Get it checked out. It should be good for another 7 years or so. A new fridge will cost $900 to $2000 and the quality of many of the new ones is not so good.
Jul 29, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Not cooling or cold
The REFRIGERATOR WAS MOVED TO ANOTHER SITE. AND IT HAS NOT GOTTEN COLD SINCE MOVE, PLUB UP 2 DAYS AGO. iT WAS UNPLUG AND CLEAN 2 DAYS BEFORE MOVE. COULD IT NEED ANTI-FREEZE?
Aug 25, 2008 | Whirlpool ET1FHTXM Top Freezer...
I have a Hoover fridge freezer. The freezer part is working correctly, but the fridge is barely cold, even at the coldest setting.There appears to be only one temperature dial for the whole appliance.
IF THE FREEZER IS FREEZING O. K., THEN THERE IS A RESTRICTION IN THE AIR FLOW. MOST ALL FRESH FOOD COMPARTMENTS GET THEIR COLD FROM THE FREEZER BY A FAN MOTOR IN THE FREEZER. MAKE SURE THE FAN IS RUINNING. IF THERE IS A DAMPER IN THE AIR DUCT FROM THE FREEZER TO THE FRESH FOOD, MAKE SURE THE DAMPER IS OPENED.
Apr 16, 2008 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
