Question about Pelco Televison & Video
How to export recorded video on a Pelco DX8100 DVR?
    Top Expert:
  • Pelco Master
  • 14,162 Answers
Converting Pelco exported video files
WHAT IS A DVR?
A DVR is a video recording and pl
ayback device that inco
rporates all of the essential capa
bilities of a VCR but adds significan
t advantages. Like
a VCR, video is recorded from one or more cameras and stored for later playback and retrieval; however, in a DVR, video data is
recorded and
stored on a hard disk instead of
magnetic tape.
Storing video in
this manner facilitates
instant, rand
om access to data, as opp
osed to sequential
access inherent to tape-based recording. This means no fast-forwarding or rewinding is necessary to locate the data a user want
s to view or
export. Another key advantage over tape is decreased maintenance. With no need to replace tapes, DVRs with hard disks can be le
ft unattended
for extended periods of time. Since video remains in the digital domain, data is easy to store, transport, and manipulate. Unli
ke analog video
recordings, digital data does not suffer from a loss in quality wh
en copied or moved from device to device. Because DVRs rely o
n hard disks
instead of tape, data storage is virtually unlimited. Video data
can also take advantage of comp
ression technology
to increase
the efficiency of
storage media. Modern DVRs, such as the DX8000, allow users to record, play back, and view live video simultaneously. Keeping d
ata digital
means video can be easily backed up to a variety of storage media.
It also means that alphanumeric
information, such as date, t
ime, and
transaction statistics,
can be synchronously recorded with video.
Posted on Jun 20, 2015
SOURCE:
Why does my color quad processor show images in black and white?
Without more information to go on I would say that it is in low light condition. If this is equipped with night vision that it records in black and white in low light situations. The recording feature on the DVR may also be the cause. Make sure you are set to record in color.
Jul 17, 2014 | Pelco Qd104c Color Quad Video Processor -...
Need to increase the hard drive to at least 6TB
Nor am I.
A 6Tb hard drive cost around $850.
You need to check if the Pelco can support a hard drive as large as this and it will need the operating system installed on this hard drive,
The Pelco may have a slot to install a second hard drive.
Oct 19, 2012 | Pelco DX4516DVD-250 16-Channel Digital...
Delete video
Log in as admin and format the HDD will remove all recoded video.
Nov 22, 2011 | Pelco DX2000 Series 16-Channel 80GB DVR
I have 6 pelco make 5104 dvr connected to a
If all of the 6 DVRs are on the same location (on the same network), and you want to remotely connect (VPN) to that location, you can Endura Enable the DVRs and then VPN to the Primary DVR. (Note that you need to be Endura Certified to use the Endura Enabled feature).
If they're all geographically distributed, you can only VPN into a single unite at a time..
Jul 15, 2010 | Pelco Video Recorder
Using RAID DVR to format multiple drives 4individual resale
Download TRINITY DISC RESCUE iso , then burn it to a disc. Get all your pcs that need the same HDD setup and connect them to a router. Boot to Trinity Disc Rescue on each machine. READ the Manual it gives a very brief description of how to clone from one drive to many, its a single command
The master machine needs to boot trinity and have a special command enabled, again its just a single command. This setup will clone one pc to everything on the network which is running trinity and the special command,
READ THE MANUAL FIRST its a brilliant resource.
Feb 08, 2010 | Computers & Internet
My pelco 16 cameras reset each one minutes
You need to do a INITIALIZATION/REINITIALIZATION PROCEDURE See below for details Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you are installing the DVR, follow the steps below to initialize
the unit as part of the installation instructions in the Installation/
Operation Manual. This procedure erases all data on the hard disk
drive and is necessary to ensure that there is no data that could cause
improper operation when you try to use it. With a clean hard drive, the
DVR can correctly index recorded video with the correct time and date.
Once the DVR is initialized, you should not reinitialize the DVR
again unless you are having trouble finding and playing back video,
and there is no other solution. If you have to reinitialize the DVR, make
sure the time and date are correct before beginning the procedure.
WARNING: When you initialize or reinitialize the DVR:
• The hard disk drive is erased.
• The password and all menu settings return to their default
conditions.
To initialize or reinitialize the DVR:
1. Press and hold the Function button. The Function Key List
appears. Keep holding the Function button.
2. Press and release the 0 button, and then release the Function
button. Enter the password if requested. The Setup Menu
appears.
3. Using the front panel buttons, enter 1220.
4. A screen appears and asks if you want to continue. Use the
Search (<</>>) buttons to highlight Yes or No to erase the
hard disk drive, and then press the Play/Pause button.
PASSWORD
The default password is 0000. If you change the password, and
then forget it, you can get into the system by using 2002.
Aug 25, 2009 | Pelco DX1000
I have pelco dx 2000 dvr of pelco brand i just want to know can i increase the recording days with new high rating hard drive from 90 days to 120 days
yes, on the configuratiion plage, use the schedule to increase the amount of time you want for
1) Sechedule recording
2) motion recording
3) event recording.
Remember, this is all based on the size of your hard drive and the number of camera you have installed.
Jan 14, 2009 | Pelco DX2000 Series 16-Channel 80GB DVR
How delete recorded movies in a Pelco DX8100
Contact the manufacturer at (800)289-9100 x 2781 for instructions on how to reformat the drive.
Dec 25, 2008 | Pelco CM9760 (CM9760VMC8) Video Matrix...
Problem in keypad
If you are using a USB Keyboard then get a USB to PS2 converter....Some times the DX8100 doesn’t recognize all USB Keyboards....Here are the links to the manuals you have requested
http://www.pelco.com/products/default.aspx?id=537
Let me know if this helps,
cbinny1
Nov 26, 2007 | Pelco DX2000 Series 16-Channel 80GB DVR
Televison & Video Logo
406 people viewed this question
Top Pelco Televison & Video Experts
Marvin
Marvin
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
