I have a pioneer model GEX XMP3. I have removed the battery,reinstalled and all I get is "Powering Up" nothing else happens. The on/off is not locked. I have left it in the charger overnight and it still does nothing. Any suggestions?
I had the same problem. My Xmp3 would just continue to say "powering up", but never fully booted. It did play normally in the dock however. I gambled and replaced the battery, and it seems to work fine now. FYI, take your time in shopping for a new battery. They aren't easy to find, and they vary quite a bit in price. I had to wait about a month XM Fan Store to get them in stock. But once it got here, it worked fine.
Posted on Jun 14, 2010
    Sergeant:
  • 449 Answers
Most probably due to overcharging and heat the firmware has becomme corrupt or any of the chip has becomme damaged. Try to re-install the firware.
Posted on Jul 11, 2009
XMp3i is stuck on "powering
Bad TSOP flash chip. No way to fix without disassembling, removing the flash chip, and placing a new flash chip on it. Doing so requires a donor radio (with another issue), and will change your XM Radio ID. You'll also need to have a hot air (or IR) rework station for desoldering the old chip, and a soldering iron for placing the new chip on the radio.
I'd say give pioneer a call since it's a design flaw, and a VERY common issue. My best guess is that it's caused by excessive heat & defective chips.
Aug 07, 2011 | Pioneer GEX-INNO1 XM Radio Receiver with...
When i turn it on it displays "please wait" but nothing else happens. I have had the GEX-XMP3 player for about a year and half. Is it toast? I've switched out different craddles, but I...
Try pulling the battery for 15 minutes, this should give you a "soft reset". Then try to use the XMP3 in portable mode, so you take the dock out of the station. See if this helps you to boot up, then see if you can go through options/settings and run a factory reset.
Jun 14, 2011 | Pioneer GEXXMP3 Satellite Radio Receiver...
Portable gex-mp3 gets stuck on powering up
The battery is definately the problem. I have seen many times in this device in particular - the battery shorts to ground - and causes the unit to malfunction.
VERY COMMON and recurring problem in the GEX-MP3
CLICK HERE to read more.
Replacing the battery is as easy as finding an Authorized Pioneer Repair center near you.
Pioneer does not sell parts to unauthorized repair techs.
CLICK HERE to find the nearest one to you. (top right of page)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 08, 2010 | Pioneer GEX-INNO1 XM Radio Receiver with...
I have a pioneer GEX-XMP3 radio. No Sound
The same thing happened to my XMP3, I had to send it to Pioneer for a replacement XMP3........call Pioneer @ (800) 421-1404, Monday through Friday, between the hours of 7:00 a.m.
and 4:30 p.m. Pacific time.
Feb 15, 2010 | Pioneer Audio Players & Recorders
I have a pioneer gex-xmp3 will not power up.
having the very same problem and my unit is only a couple months old . has been nothing but problems but at least it would turn on then , nothing now. I removed it from base and attempted to trn it on ..... nothing but PLEASE WAIT . I:M SO SO SO mad
Sep 04, 2009 | Ministry Of Sound Audio Players &...
Pioneer Model GEX-XMP "please wait" problem
Remove back cover and leave battery in. There is a tiny hole that you can use a small paperclip to do a RESET. After that, plug your AC adapter directly into the bottom of the radio. Go to MENU and select "SET FACTORY DEFAULTS". Then turn off, wait a minute, turn back on again and select "mode" to see if you can hear your prerecorded music. If these don't work, then you likely do have a defective unit. Let me know how this works for you - okay?
Regards,
John
Aug 22, 2009 | Pioneer AirWave XM2Go Satellite Radio...
Volume control
Remove the back battery cover only. Turn unit on. Insert a tiny paperclip thru the tiny 'reset' hole on the back of the unit inside the battery compartment. OK?
Aug 05, 2009 | Pioneer XM2go Inno Satellite Radio...
I connected my Pioneer GEX-XMP3 player through the auxillary terminals on my Bose Wave radio and the sound is very low. I connected it as stated in the satelite radio book. Help!!
Hi have you set the vlume of the MP3 player to its maximum? You need to do so since the AUX input behind the unit does accept fix line input as standard.
Glad to be of service...
Mar 29, 2009 | Bose Wave Radio
Pioneer GEX-XMP3 stuck in the power up mode
Just off the phone with Pioneer customer service. Apparently a "software glitch" common enough that an internal memo has gone out to replace units under warranty without further trouble shooting. The last step in the process was to remove the battery, place in the original charging cradle without the battery, and hold the power switch down for 10-15 seconds; if the "Please wait" message continues, the unit is defective.
Feb 23, 2009 | Pioneer AirWave XM2Go Satellite Radio...
568 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
