Question about Hoover Vacuums
I need the electrical wiring diagram for a hoover wind tunnel canister mod. s3661. Thank you
Buffalo12980
  • 625 Answers
SOURCE: Hoover Self Propelled wind tunnel vacuum U6433-900
please go to thehooverstore on the web. they'll have an exploded diagram of how your machine goes together. I'm sure you'll find your solution there.
Posted on Sep 22, 2007
SOURCE: Hoover Wind Tunnel ON/Off Switch
This happens all the time on our vacuum. Just remove the handle and switch the button manually inside. You will have to do this from time to time as the power switch on the outside will constantly stop working. This, along with the belt replacements are the common complaints on this machine.
Posted on Jul 28, 2008
Pnutgllry
  • 57 Answers
SOURCE: Hoover Wind Tunnel bagless- issue with turning on
Have you tried to plug the vaccuum in another outlet that is on another breaker? It could be the vaccuum tripped the breaker. Turn the breaker back on. The manual mentions the thermal protector could have been activated. If this happened it resets and your vac should run after 30 minutes. I have a Widepath Tempo and it has tripped the surge protector. If this is the problem try turning some things off that are also on that breaker/outlet, or unplug them when you use the vac.
Posted on Jan 06, 2009
  • 30 Answers
SOURCE: Hoover wind tunnel vacuum cleaner shuts off during use
Motor front bearing retainer probably melted from grit. Replace motor. The motor's rotor is dragging on the stator.
Posted on Mar 27, 2009
  • 430 Answers
SOURCE: I bought Hoover Wind tunnel central vacuum 2 weeks
There is a hinged bracket for this unit which has a 5" bolt through it. It comes from CanaVac who manufactures under label. If you cannot find this large U shaped bracket on the body or in the bucket, either return to COSTO or call Canavac and explain. A used bracket from an old Canavac will fit, nothing else will. If Costco is sold out you will not likely get one through a Hoover service center since they just don't break and it is a newer body style for Hoover made under private label.. A Canavac dealer might have one around
FYI if you got this unit at $200 off you got good value, if you paid full price and need to wait for a bracket, shop around for a different brand. While the unit and tools are good , the Hoover power head is the Achilles heal on this package. If you use it more than an hour a week , you will wear it out within 3-5 years as it is their light duty head.
If you have the bracket , hang the unit on a double stud if possible or 3/4 plywood braced across two studs. Leave 24-36 inches slack in your low voltage wire at the motor and coil around a pencil or long philips screwdriver, making it phone cord style... your wife and neighbors will think you are a pro......
Post back if you need more info.
Posted on Oct 16, 2009
I have Hoover wind tunnel canister vacuum,it keeps coming apart where hose connects to power head,! Ready to toss this thing!
Take it to your local vac shop before you toss it. Then at least you will know if it was repairable or not. They can also show you some better quality machines to replace it with if you need to.
May 22, 2017 | Hoover Vacuums
Hoover 30600 max wind tunnel less than a year old makes a whistling noise
Ours did too. I bought a Dyson.
Check for gaps in the hoses and in the wind tunnel canister. Something is not sealing properly.
Nov 11, 2016 | Hoover Vacuums
Why is my hoover wind tunnel blowing out side filter and not suctioning
Perhaps dirt or hair is stuck or the full canister needs to be emptied, remove blockage and suction should return.
Jul 15, 2014 | Vacuums
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Where can I find an extension hose and wand for a hoover wind tunnel bagless canister model S3755 (59134002)
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=673664
Generic problem for all Vacuums
Where can I find an
Posted by 1socalgirl on Jun 15, 2008
Where can I find an extension hose and wand for a Hoover wind tunnel bagless canister model S3755 (59134002)
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can check with your local vacuum cleaner dealer and sometimes they have them in stock or they can order them for you. Or you can call the Hoover Factory customer service line and they will get you in touch with the Hoover parts Dept and they can ship you the extension hose and wand need for your vacuum. Please include the Model # and the Serial # so they can get the right item and color. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 15, 2008 | Vacuums
Vacuums Logo
131 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
