Question about Acer AL2017 20" LCD Monitor
Connecting dvi cable straight to acer monitor
Connected a dvi cable from the back of my cable box to monitor's dvi input and it say's on screen input not supported. What does this mean.
  • Rivercity Feb 10, 2008
    Same exact issue. Using HDMI to dvi cable connected to scientific atlanta cablebox hdmi out port to acer dvi in and changed selection via monitor menu. still get input not supported.
  • Humanculus Mar 31, 2008
    I have a Scientific Atlanta box with my AL2216wbd and I'm having the same problem.
    The cable guy is coming within a few days.  I looked in the specs sheet that came with the box, and it said, "For an HDMI to DVI connection, use an adapter."  I've seen dumb and smart adapters on eBay, maybe one of these would solve this problem.  I'll let you guys know.
    Darn, Mac Safari is nice.
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Posted on Jul 28, 2008
Connect my Acer monitor to my digital cable box.
Not sure what your cable box outputs but connect your cable box to a tv and try changing the resolution of your cable box to 1600x900 or less if there is such a setting; the monitor will not display resolutions higher than 1600x900
May 08, 2014 | Acer X203H bd Monitor
No signal
Press the Function Button to open the short cut menu. Locate the Input graphic and press the button for it. Each time you press the button, it will cycle between DVI and VGA input jacks. Allow a few seconds for the display to switch inputs. Make sure that cable is connected securely to the associated jack in the back of the monitor and the computer (or other source). If either VGA or DVI input is selected ,but the VGA and DVI cables are not connected, a floating dialog box indicates:
"No Cable Connect" or "No Signal"
Your manual can be viewed here:
Apr 07, 2014 | Acer S201HL BD Refurbished LCD Monitor
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
How can i use my acer monitor as a tv i lost my manual
The manual won't help you to much in this regard.
This monitor is a standard type that has both a VGA and DVI input.
Normally what you would use with a personal computer.
If you want to use it as a TV monitor you will have some sort of device that outputs to VGA or DVI.
DVI stands for "Digital Visual Interface" and it's preferable over VGA as it should potentially give you a better image.
This means:
A) A computer. You can build your own media TV and watch internet streamed shows like Hulu, Netfix, use as a DVD player, etc. I recommend this route. No more dependance on Cable companies! You just need internet.
B) Find a DVD, and, or Tuner/Cable/Satellite box that has these outputs.
If you want to use Cable or Satellite, contact your provider company and see if they have a box that will output to either VGA or DVI. Might have a hard time finding one of these, or it might cost more then it's worth.
C) Buy a S-Video input to VGA/DVI output. You can buy these for around $40.
Then you should be able to hook it up to just about any device as most modern TV devices will have an S-Video outputs.
Feb 17, 2011 | Acer AL2032WD 20" Flat Panel LCD Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
The screen flick when connected to Samsing Sync
Hello there!
Screen flickering can be caused by instability of cable you are using, or it can be also caused by difference between power input, so check your power plug ,where your monitor and pc are plugged, make sure they are ok for your region, and check those cabels. Also check settings on monitor for what input you are using DVI or VGA or both at the same time.
Aleksandar Adzic
Apr 16, 2010 | Computers & Internet
After Microsoft splash screen the monitor goes blank except for "no signal" messages if I turn off/on the monitor. I checked the monitor menu. Under Misc dropdown the Input is empty. Clicking input bring s...
Please check whether you are using a DVI (Digital Visual Interface) cable or VGA (Video Graphics Array) cable to the monitor.The monitor will adjust automatically to the requirements of the connected cable.From the question I think you had connected a DVI cable to the monitor.Make sure that there is no loose contact between the ports and the cable.Also make sure that the proper settings on the monitor are done for the DVI cable configuration.
Mar 07, 2010 | X2Gen MV20TP Monitor
Computer is on, monitor light is on, screen is dark
You may have the wrong input setting set on the monitor. By using the menu button on the monitor, you can set the input to VGA, DVI, or whichever medium you have your monitor connected by. If this does not seem to solve the issue, try another cable to ensure it is not an issue with the cable itself. I hope this helps.
Good Luck,
Jan 31, 2010 | Acer X193W LCD Monitor
Are acer monitors unable to pick up HD video inputs?
There are two types cable to connect to LCD Monitor. VGA and the other is DVI,ight need DVI cable it has flat pins and is larger than the VGA small round pin models.
Dec 21, 2009 | Acer X193W LCD Monitor
No Display from new Acer Desktop AX1700
check all power cable. check vga cable,
Jan 26, 2009 | Computers & Internet
Acer AL2017 20" LCD Monitor Logo
979 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
