Question about Canon PowerShot SD890 / IXUS 970 IS Digital Camera
WHAT IS THE AUTHENTICATION CODE?
MODEL NUMBER: DIGITAL CANON IXUS 970 IS - CANON PC 1266 NO. 6743101748
SOURCE:
SOURCE: canon digital ixus 700
I understand that it takes a maximum of 2GB. Still loads of photo/video capability. Don't make the mistake I did of buying a 4GB SDHC card for it. It won't take it.
Posted on Sep 28, 2008
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Posted on Oct 25, 2008
Shiblie
  • 34 Answers
SOURCE: camera thinks memory card is locked
check the pins where the memory card enter, if they are all there (not bended) go to canon site and download the latest framework.
P.S, mack sure to use the right SD Card type as the camera is compatible with some types and with a limited size only.
Posted on Feb 05, 2009
t00nz
  • 4738 Answers
SOURCE: Canon IXUS 970 IS Digital Camera Lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 21, 2009
  • 4 Answers
SOURCE: canon digital ixus 850is card locked! message
.....Open your memory card........Adapter And see There IZZ a ThiNg named Lockand UNLOCk That!!!! i guEsS that woULd Work.....
Posted on Feb 21, 2010
Testimonial: "many thanks for unlocking my card Is is an 8g card expensive for a pensioner. it had just a few photos on it. Thankyou again Peter"
Canon IXUS 970 IS will not recognise 2GB SD card although it used to do so
The memory card might have been damaged.If it was a problem with your camera it might not have recognized your 32k sd card.
So buy a new sd card.
Jun 10, 2012 | Canon IXUS 970 IS Digital Camera
Canon IXUS 970 IS Someone played with my camera & now everything is in Japanese. How do I change the language back to English?? Thanks!
Press the playback button (right-pointing triangle). Press and hold the FUNC/SET button and press the menu button. Use the cursor keys to select the language and press the FUNC/SET button.
The instructions are in the "Setting the Display Language" section of the manual (page 15 in my copy). If you need a copy of the manual, you can download one from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd890_is#BrochuresAndManuals
Jul 09, 2011 | Canon PowerShot SD890 / IXUS 970 IS...
Canon IXUS 970 IS manual
The IXUS 970 is called the SD890 in some parts of the world. You can download the manual and more for the SD890 from
Dec 23, 2010 | Cameras
WHAT TYPE OF BATTERY RECOMMENDED FOR CANON IXUS 970 IS
The recommended battery would be:
Li-Ion
3.7 V
1120 mAh
SKU: DCA-5L
Price is +- $15
Regards
Nov 28, 2010 | Canon IXUS 970 IS Digital Camera
I neeed a manual for Canon ixus 97015
You can download the manual and more from the manufacturer's web site at
Sep 09, 2010 | Canon PowerShot SD890 IS / IXUS 970 IS...
How to plug back the lcd connector on a ixus 970
if it is a standard ribbon connector that you are trying to reconnect you will find there is a small piece of the connector that either slides up or hinges upwards through 90 degrees. this releases the clip pressure to reinsert the ribbon then closing it holds it secure
Mar 02, 2010 | Canon IXUS 970 IS Digital Camera
Canon IXUS video problem
Use a card reader to download them to a folder you create on your desktop.
Feb 16, 2010 | Canon IXUS 970 IS Digital Camera
Lens error with Canon ixus 970 IS
Has anyone responded to you on this yet - I have had the same problem and don't know what to do?>
Apr 07, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
CANON IXUS 970 IS
maybe the lens has shifted, try taking it to Canon Service Centre, (it will be fixed FOC if it's under warranty) as it does not need any spare parts, just reassimbling the lens with the body.
Oct 22, 2008 | Canon PowerShot SD890 IS / IXUS 970 IS...
Camera thinks memory card is locked
Oct 01, 2008 | Canon PowerShot SD890 IS / IXUS 970 IS...
Canon PowerShot SD890 / IXUS 970 IS Digital Camera Logo
52 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
