Confidence TXI Heavy Duty Motorized Electric Folding Treadmill Running Machine Logo
Emma Sheridan Posted on Jun 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belt sticking when running, is it me or the machine????
Don't notice as much when holding onto bars but soon as let go, sticks and throws off ballance
Bill Boyd
Level 3:
Top Expert:
  • Confidence Master 53,816 Answers
  • Posted on Jun 20, 2015
Bill Boyd
Confidence Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11946321
Points
172802
It could be the belt sticking under foot on the slide plate
ask the sports shops if there is a lubricant that you can used under the belt
check to see if the belt is correctly adjusted
2answers
Why does my deck belt come off?
check the alignment of the pulleys for that belt check that the correct v section belt is in use
Jun 12, 2017 • Garden
2helpful
A smell like burning rubber comes out of the vents whenever it is used. It starts as soon as the vacuum is turned on. I've emptied the filter, but maybe I need a new one? I don't think the suction...
Hi sevillekathe...
The problem is that you have is that hair,strings,etc has gotten wrapped around the beater bar of the vacuum and it is trying to slow down the motor but the motor will not slow down so the smell you smell is the belt burning up because it is slippling and creating smoke and smell
You will need to remove the beater bar from the bottom of the machine and clean the hair,strings,etc from around the bearings on each end of the beater bar.
Also check your filter bag, check the hose going to the vacuum if you have one for blockages, and once you have the beater bar off check your belt condition and look for blockages going to the bag.
Please take time to rate me
My wife noticed smoke right after starting the washer. She immediately turned it off and called me. I noticed a smoke smell which smelled more electrical than rubber. The basket spins easily. The washer...
Thanks for choosing FixYa and welcome to the site. There are a few things that you can check. First, check your belt. It may have worn or the pulley may be sticking. The belt may be causing the smoke. You might want to check your control board just in case and see if you see any damaged wires. You need to try and see if the washer throws out any error codes. I really don't know what else you could check because there are no symptoms. It could have come from the water pump or the motor drive also.
How to remove and install serpentine belt
Still need help? For the I6 engine, stick a 3/8" socket extension (just the extension) in the square hold in the belt tensioner. Stick a breaker bar on the end of the extension and turn clockwise to get the pressure off the belt, and remove the belt. Replace in reverse order.
What does the timming balancer belt do on a 91 accord lx 2.2
The Ballancer Belt runs the ballancer shaft which was installed in the motor from factory to help offset vibrations in the motor or counter ballance for the engine to run smoother
1helpful
I need written instructions for EA Sports MVP Baseball for Gamecu
hope these are the right ones
MVP Baseball 2005
BATTING
Z Button Z + A Button = Square to Bunt (release to pull back)
A Button Swing
BASERUNNING
Control Pad Steal / Choose base destination (press toward base you are trying to steal)
Slide Refer to EA SPORTS Big Play Control in Gameplay below.
C Stick Left/Right = Increase/decrease leadoff.
X Button Control runner at 1st
B Button Control runner at 3rd
Y Button Control runner at 2nd
L Button Advance/stop all runners
Z Button Advance/stop all runners
R Button Retreat runner
PITCHING
Control Stick Choose pitch location.
A Button Throw a pitch
X Button Throw a pitch
B Button Throw a pitch
Y Button Throw a pitch
White Button (press and hold) + Directional Pad Up/Down (Left/Right to toggle between bullpens and dugouts) = View Bullpen/Dugout menu
R Button Throw a pitch
L Button + X, B or Y = Pickoff attempt. L + A = Pitchout. L + Control Pad Down = Intentionally hit the batter. L + Control Pad Up = Intentionally walk a batter.
Z Button (Hold) + Control Pad Up/Down = Choose infield/outfield alignment (before pitch). Left/Right to choose a category. Z Button (hold) + C Stick Left/Right = View pitch history, to toggle at bats. Z Button + Control Pad Up/Down = View Bullpen/Dugout menu (Left/Right to toggle between bullpens and dugouts).
FIELDING
Control Stick Move fielder
C Stick EA SPORTS Big Play Control
A Button Throw to home (press and hold to power up, release to throw)
X Button Throw to 1st (press and hold to power up, release to throw)
B Button Throw to 3rd (press and hold to power up, release to throw)
Y Button Throw to 2nd (press and hold to power up, release to throw)
R Button Throw to the cut-off man
GamePlay:
EA SPORTS PURE SWING SYSTEM:
The Strike zone is divided into nine colored squares. Red squares mark the batter's hot zones. Blue squares are the batter's cold zones. Clear squares are neutral for the batter.
Take unprecedented control at the plate by moving the Control Stick during your swing.
-The results of your swing depend on your timing, the location of the pitch, and the direction you move the Control Stick.
-For the best results, move the Control Stick towards the location of the pitch.
-To hit the ball in the air, move the Control Stick Diagonal Up-Left / Up / Diagonal Up-Right while swinging. This increases the chances of hitting a fly ball, but also increases your chances of missing the ball if the pitch isn't up in the zone.
-To hit the ball on the ground, move the Control Stick Diagonal Left-Down / Down / Diagonal Right-Down while swinging. Keep in mind that high pitches are very difficult to hit on the ground.
-To hit the ball to the left, move the Control Stick Diagonal Left- Down / Left / Diagonal Up-Left while swinging. For the best results, use this when the pitch is coming in on the left side of the plate.
-To hit the ball to the right, move the Control Stick Diagonal Right-Down / Right / Diagonal Up-Right while swinging. For the best results, use this when the pitch is coming in on the right side of the plate.
TO THROW A PITCH:
1. Press and hold the button that corresponds to the pitch you want to throw. The bar inside the pitch meter begins moving.
2. Release the pitch button when the bar reaches the end of the pitch meter. The closer your release point is to the end of the meter, the more effective the pitch is.
3. Press the pitch button again when the bar is within the green accuracy zone near the beginning of the pitch cycle to determine the pitch's accuracy.
-The effect of a bad pitch depends on the type of pitch. For example, ineffective fastballs are slower than normal, and less effective breaking pitches are flatter.
-If a pitcher misses the green accuracy zone by a considerable amount, an indicator (red for hot zone, blue for cold zone, yellow for ball, white for neutral) appears to tip off the batter to the location of the pitch.
PITCH SELECTION
Your pitcher's pitch selection appears on-screen. Not all pitchers have the same arsenal of pitches. A pitcher's four-seam fastball is always assigned to A Button. The remaining pitches are assigned to X, B, Y and R Button (though not all pitchers have five pitches).
FIELDING
-If you power up the throw into the red zone, you throw harder, but less accurately, which could result in an error.
-If you select to throw to either a base or the cut-off man before the ball arrives, the fielder begins his throw immediately upon receiving the ball.
NOTE: The CPU automatically adjusts your defensive alignment based on the situation. However, you can override this by choosing the infield and outfield alignments yourself.
EA SPORTS BIG PLAY CONTROL:
Using the all-new EA SPORTS Big Play Control, you can climb the fence to rob home runs, make spectacular diving catches, slide around tags, and more.
FIELDING:
- To dive or stretch for a ball just out of your reach, move the C Stick Left/Right toward the ball.
-To climb the wall to snag a would-be home run or jump for a ball over your head, move the C Stick Up.
-To make a sliding catch, move the C Stick Down as the ball approaches.
BASERUNNING
Timing is the key to a perfect slide. Use EA SPORTS Big Play Control to create havoc on the base paths.
C Stick:
Up = Head-first slide
Diagonal Up-Left/Up-Right = Head-first slide to the left/right side of the bag
Down = Pop-up slide
Diagonal Down-Right/Down-Left = Hook slide to the right/left side of the bag
Up = Dislodge ball from catcher.
4helpful
How to stack instructions
I just bought one of these, and the install is pretty simple.
you have 3 pieces, 2 of them go on the sides, 1 goes across the front.
you lay the side pieces on top of the washer so that the little tabe are sticking up,  the end that has 2 tabs and a hole for the screw goes at the back.  once they are laid in place, you put 1 screwn in each piece on the back of the washer (there are holes in the washer for this already) then you put the dryer on to so that the little tabs that stick up kind of hold the feet.
you put the front bar on last so that it's tabs hold onto the front feet, then you screw both ends of the front bar into the side bars.
Changing belt
take the water and solution tank out of the machine. turn it over an on the left hand side you will see a red clip with a screw in it. take out that screw. flip the unit back over and take off the belt access cover by sticking a straight screw driver down into the slots and popping the clips to release the cover. tilt the machine to the side and using your finger wiggle the red plastic piece down out of the way. the beater bar on that side should be free. make sure both belts are in good shape because the belts run the beater bar and the second belt runs the water pump.
Lg wash machine metal sticking throw outer drum
pull washer out and remove card board in back of machine. inspect internalls to see where bar came from. its probably a loose bolt. do not remove cement block for this is your stabalizer. you should see clear paint or scratches where bar came from. replace bar with new bolts. run the machine in dry mode to see if its ok. if motor and belt is ok you should be allright. butttttt if bar went threw inner brum you might be better buying a used washer.
Top Confidence Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
john h
Are you a Confidence Exercise and Fitnes Expert? Answer questions, earn points and help others
