Question about HP PhotoSmart p1100 InkJet Printer
Problem w/ Duplexing Attachment on HP PhotoSmart P1100 Printer
This printer has a rear-mounted attachment that enables duplex printing. I've encountered a hard failure - paper jam occurs every time I attempt 2-sided printing. Previously, duplex printing had been very reliable (don't recall a jam of the duplexer prior to hard failure). Paper stock has not varied.
Thank you for any assistance you can provide.
  • Anonymous Jan 19, 2009
    The duplex stopped working all of a sudden. I've cleaned the rollers with a damp cloth but to no avail. I've turned it off and will see if that works by any chance.
  • Anonymous Mar 25, 2014
    message on printer
  • 4 Answers
Maybe this would help:
Open the access door on the duplexer and clean the rollers with a damp cloth. If that solves the problem, I suggest using rubber rejuventator as a long term solution.
Posted on Nov 15, 2007
Using hpprinter & Win Vista 8.1
If your printer is a duplexer (prints on both sides automatically) u need to set that in the printer properties when U start to do the print job. If its not a duplexer U need to set it up for manual duplexing and follow the instructions
Aug 08, 2014 | HP Photosmart 5520 e-All-in-One -...
Printing on both sides
Make sure the Automatic Duplexing option is enabled:
Enter Control Panel then Devices and Printers.
Right click the printer icon, then Printer Properties.
Click the Device Settings tab.
Set the Automatic Two-Sided Duplex Accessory as installed and click OK to save.
Now Automatic Duplexing should become available.
My LaserJet 1320 will no longer do duplex printing with Windows 8
Aug 07, 2014 | HP LaserJet 1320 Printer
Hp laserjet 4300 dtn tray one pickup
Yes,
Adding the duplex attachment makes the TN a DTN nothing different in the firmware of the printer.
Feb 05, 2013 | HP LASERJET 4300DTN Q2434A LASER PRINTER...
I am trying to set the printer to automatic duplexing...?
Hi
If you want to set Print on Both Sides (duplex) as the default setting for all print jobs (even single page jobs) use the following steps.
  1. Click Start , Printers or Printers and Faxes from the Microsoft Windows desktop.
  2. Right-click the HP Color LaserJet 2605dn_2605dtn and select Printing Preferences (Properties in Microsoft Windows 2000).
  3. Click the Finishing tab.
  4. Select Print on Both Sides under the Document Options section.
  5. Click OK to save the setting and close the Printing Preferences window.
  6. Close the Printers or Printers and Faxes folder.
Note:In this scenario, all print jobs, even single print jobs, will be treated as Print on Both Sizes (automatic duplexing) for media that is supported by the duplexing unit. For media that is not supported by the duplexing unit, the job will be treated as Print on Both Sides (Manually) (manual duplex).
Jun 13, 2011 | HP LaserJet P4014n Printer
Can't print duplex on p2015d with pcl6 driver on windows 7 Only allows manual duplex with universal print driver pcl5 and pcl6
Hello, not all of the P2015 Series printers support Automatic Duplexing. Are you sure you have the correct model printer? Only the P2015D/DN/X support this feature. Check the front cover, it will have the model listed... In the printer driver, check the device settings, see if duplexing is an option and enable it.
Jan 15, 2011 | HP LaserJet P2015d Printer
Does the hp psc 750 do double sided printing
I have not used that specific printer, but from all I can determine, it is not a duplex printer. However hp offers these suggestions on how to determing if your printer is duplex: <br /> "To find out if your printer supports duplex printing, refer to your printer manual or look for the <b>Two-sided (Duplex printing)</b> or <b>Print on both sides</b> drop-down menu in the <b>Printer Properties</b> dialog box on your PC (sometimes found in the <b>Printer Shortcuts</b> tab).<br /> If you can
Aug 20, 2010 | HP PSC 750 All-In-One InkJet Printer
LaserJet 5MPHP
Only if you print the first side then place the paper back into the printer to do the second side. Also referred to as manual duplexing. This printer has no automatic duplexing option.
Also keep in mind that the percentage of duplex prints you do should be very low as this printer has no method of cleaning the fusing unit as most printers do that are made for duplexing. The industry standard is 2% or less should be duplexed.
Jan 05, 2010 | Office Equipment & Supplies
Getting the Duplex Attachment to Work with Vista
what printer do you have?
brand and model?
do you has installed the newest driver and utility for vista operating system?
do you know that Vista and XP are incompatible in terms of drivers?
Vista has many drivers for a lots of printers, but these drivers are "generic driver". The generic driver is a small driver, an incomplete driver, and has a limited functions.
Sep 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PhotoSmart p1100 InkJet Printer Logo
359 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
