Question about Vacuums
Same Shut Off Problem as Hamster71
I have the same model LUX7000.  My machine is doing exactly the same thing.  It shuts off and indictates the bag is full when it is brand new.  The top filter (HEPA) is in place and clean.  I have tried running the vacuum without that filter and it still does the same thing.  I have blown everything with a high presure air hose, I have vacuumed the unit with a shop vac and tried everything I can without success.  One thing I noticed is when the knob on the top that adjusts how sensitive it is to the size of particles before the machine shuts down is set lower than the most fine setting,  the machine even shuts off more quickley.  The only way to get it to run at all is to make that setting for the finest particle setting.
I have an older Regency Series 1500 Electrolux, Model 1515. The hose is clear, there's a new bag in vacuum and as soon as I get close to putting the hose on, the vacuum shuts down and the bag full light comes on. Just putting my hand close to the opening will do the same thing. I've tried with and without a filter, same thing happens. Looking for ideas! Thanks
  • 27 Answers
Re: Same Shut Off Problem as Hamster71
The part that you call the particle size sensetivity adjuster is bad. There are 2 seals in the assembly, the lower seal is slipping out of place because the plastic lip which keeps it in place is broken. Split housings and replace part. This machine is alot of work to take appart and get back together correctly. Might want to bring to local vac shop. good luck.
Posted on Feb 23, 2008
0 characters
3 Points
Lately as I'm vacuuming, my vacuum will turn off. I can start it again, and it will shut off again. It seems like a power issue. Happens different places in the home, so it is not the outlet.
Some vacs shut off when the dirt bag is full Check your brush area and see if there is dirt or bits of string like things wrapped around the brush or the brush ends. This will cause the machine to shut down as well if there is pressure holding the brushes. Will it run if you wiggle the plug if so you could have a bad plug as well.
Jul 07, 2015 | Kenmore Vacuums
What does the key light stand for on lux7000 canister vaccuum?
The light on the top of the 7000 that represents a "key" as you state it, is actually a "No Bag" light. That means to check the bag compartment for a bag. Replace if you do not see one. Close the door, push the start button, and will start. If it doesn't , make sure the bag top (cardboard) is flush inside. It may be missing the bag switch. Hope that helps!
Oct 11, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Eletrolux lux7000 manu and how to retract the power cord?
For the user's/owner's manual, go to the below link, click on the arrow below where it says "Older Models", click on Lux 7000, click on "download". If you want a service manual, they are only available to Aerus Electrolux stores.
For retracting the cord, try tipping vacuum up on it's back end and gently pulling and releasing cord. This will often cause it to retract. If not, keep in mind that the canister portion of this vacuum has a 7 year warranty on it, so depending on when you purchased it, the cordwinder may still be covered. The warranty does not cover normal wear and tear, or abuse. There are other things that will void the warranty.
Nov 26, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
My handheld vaccum bag got full and the machine shut off. i cleaned the clog, replaced the bag, and the machine won't turn on.
Depending on the make and model you can sometimes find a reset button on it somewhere.. If I knew the make and model I could be more helpful with your issue. Thanks for choosing Fixya.
Oct 12, 2010 | Oreck Vacuums
Can't get my lux7000 to run
Make sure the bag is in place correctly. The question mark light indicates that there isn't a bag in the machine. There is a small button in the front of the bag housing that is depressed by the cardboard top of the bag. I think it is located in the bottom right hand of the bag housing if you are facing the front of the machine. Make sure the bag is depressing this actuator when the front of the machine is closed. If it is, it may be an internal problem with the switch. Good Luck!!
Jan 03, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Most likely the pcb in the cannister is bad, part # KC86WBZRZ000
Sep 01, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
hey just thought you might like to know that I have been given an answear on the same problem log in to get the info. Now I just need to know how to open it without breaking it!
Oct 26, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Help me fix my LUX7000
Turn the dial down to its least sensitive setting and try that. If not you can call my office at 570-326-1731
Oct 20, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
203 people viewed this question
Top Vacuums Experts
Roger Potts
Are you a Vacuum Expert? Answer questions, earn points and help others
