Question about Mastercool 67680 Evaporative Cooler Air Conditioner
I installed a digital thermostat to my Master Cooler. After the pump runs for a few mintues the Fan shuts off. What did I do wrong?
  • 3,230 Answers
It seems like you do some wrong with wire connection, may be some wire get loose or may be some short circuit, check that.
Double check that all.
Thanks
Posted on Jul 12, 2009
Running cooler than normal (indicated by temp gauge), hot air not hot, thermostat not the problem (recently replaced), check engine light NOT on.
as far as the temp of the air blowing...it in direct proportion to engine coolant temp...try a hotter thermostat....as for the faan running continuously that is a seperate problem and sounds like a faulty rheostat or fan switch...rheostat is elect, switch on the fan motor that enables different speeds and may beinternal on your truck. only parts store will know . if it is replace fan motor. if not , test switch and then test rheostat
Feb 09, 2014 | 2002 GMC Sierra 1500
Will not stop running
Are you referring to the compressor not shutting off down below or the evaporator fan inside the cooling area not shutting off? Evaporator fan always runs the compressor is controlled by the thermostat you could have a bad thermostat if the compressor never shuts off.
Mar 13, 2013 | True GDM-7 Beverage Cooler
Wiring a master flow PT6 thermostat to attic fan
I had a roofer install Master Flow PRO 3 and he did the initial wiring incorrectly. The black wire pairs were incorrectly connected and caused the fan to run 24-hours. I switched the black wires pairings and the fan shuts off if less than 100-degrees (the setting I chose) and comes on if more than 100-degrees. You may want to be sure that the black wire from the power source is connected to the black wire for the thermostat (black wire nearest the thermostat setting switch and closest to the power source wire). The black wire from the fan motor should be connected to the black wire closest to the fan motor's wire.
Aug 01, 2012 | Cars & Trucks
Mastercool plus 6500 thermostat problem
Posted also on the Cooler quick cycling problem:
My Master Stat Controller (CC2000A Rev 2003) was in 2 parts. The Thermostat unit in the house and the Power Control unit in the Cooler. The power Control unit was mounted on the squirrel cage fan housing so it vibrated some when running. That means the components vibrated slightly with respect to the PC board. Especially the larger components. My first symptom - Intermittent failure to turn the water pump on. I could see a faint crack in the solder around the pin of a relay on the PC board. Re soldering the PC pins solved that problem. Later, the second symptom was quicker than usual on-off cycling of the fan. I re-soldered all the pins on the PC board and all problems subsided. A better mounting place for the Power Control Unit would be good, but outside of the cooler might be a thermal problem here in the hot desert south west.
Apr 24, 2012 | Mastercool 67471 Evaporative Cooler Air...
Have a master 165,000 btu turbo heater it always starts and runs but sometimes it will run for 5 minutes 7 or 10 no matter where i set the built in thermostat,any tips ????
I would start by checking the fuel filter form the tank to the nozzle. If this is getting dirty the heater will slowly start loosing the red glow on the nose cone until the until shuts down.
Normally if it sets for a few minutes it will start and run again.
You can order a filter replacement kit that has all of your filters included.
Nov 03, 2010 | Master Heaters Master B115DT 115,000BTU...
Ive got a 323ci bmw on a 2000 plate with 23000 overheatin
repl temp sensor. run 12v to motor, does it run? could be resistors, they're hidden all over the car, thanks to the ******* engineers that put this piece of **** together. or the fan blades could be blocked.
radiator clogged, did someone put stop-leak in it? Remove thermostat drill two 3/16" holes in it 180degress apart, install 12 degree cooler thermostat.
check to see if fan clutch is working properly.
Jul 10, 2010 | 1999 BMW 323 Series
650 over heating
check the thermostat it could be sticky or just stuck shut it could also be,,, a blocked rad,,,, running with a very week fule mix, (wrong muffler fitted will do this),,, a water pump fault,,,, or a faulty water temp censor,
or worst,,,a head gasket blown!!! or cracked block!!!
change the thermostat first, its the cheapest part,
Jan 14, 2010 | 2007 BMW G 650 Xchallenge
Compresor turn off every 3 mintue
ya the compressor might be switch off by the thermostat . the thermostat setting might be not cool or # 2. Or thermostat need replacement if you had set it to the cooler side.
Jun 16, 2009 | LG BG8000ER Air Conditioner
Master 115,000 will not stay running
It sounds as if your are having a fuel delivery issue. Always start troubleshooting fuel delivery problems with a pump pressure test. Air pump pressure is extremely critical on these computerized heaters. Instructions are at www.reddyparts,.com
Dec 03, 2008 | Master Heaters Master B115DT 115,000BTU...
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
55 people viewed this question
Top Mastercool Heating & Cooling Experts
Paul
Paul
acrman404a
Steve F
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
