Question about Fax Machines
Canon fax/copier Just looking for a user or programming manual for a Canon laser class 7000 fax/copier so I can remove the old name, and set the time on the fax. Thanks
  • 4,889 Answers
Re: Canon fax/copier
1 Data Registation
2 Set
3 Set (when User Settings displayed..includes date, name etc.,)
4 Time & Date
5 Set etc..
Posted on Nov 15, 2007
Cal this number at canon 1-866-226-6634
Posted on Apr 14, 2009
0 characters
3 Points
Am I able to fax to multiple recipients with canon lc 2050p?
Yes. Here is a link to your Canon Laser Class 2050P fax machine's User Guide. Reference pages 5-1 through 5-28 for Speed Dialing, One-Tuoch Dialing, and Group Dialing. Speed Dialing must be set up before Group Dialing can be assigned. Group Dialing will accomplish the multiple recipients sending.
Dec 14, 2009 | Canon LaserClass 2050 Plain Paper Fax
Check Printer error
1)need to replace the fuser unit assy.
2)this is useful link
3)Pls feedback me .Thanks
Aug 11, 2009 | Canon LaserClass 7000 Plain Paper Fax
My Canon Laser Class 7000 has a problem on the pick up to pull the paper into the machine. Every time it goes to print a fax, the paper gets jammed. I clear it out and it happens again and again. I...
Easy one. This unit has several parts in the automatic document feeder (aka ADF) that simply wear out. As far as I know the parts are still availble from a reputable canon repair center. The lower feed assy is the most likely contributer to your issues. This is sold as an entire assy. Not exactly for the faint of screwdriver. Should be done by a skilled tech.
Good luck
Jul 27, 2009 | Canon LaserClass 7000 Plain Paper Fax
Canon Laser Class 7000 Fax won't print
Error code ## 322 indicates that the Fuser not heating (Usually cause by a Bad Fuser Module)
Mar 03, 2009 | Canon LaserClass 7000 Plain Paper Fax
Canon Laser Class 7000 - 'RECEIVED IN MEMORY' showing on display
Hello Tony,
You are right about that. The messages are indeed sitting in memory.Here's the procedure to print them out.
Step1: Press the memory reference button in the one touch speed dial panel
Step 2:Press the search keys(arrow keys under the one touch dialing panel)until the option "print document" is highlighted and then press SET.
Step 3:Press the search keys again to select the transaction ID of the document you wish to print and then press SET.
Step 4:Press # to print the whole document or * if you wish to print only the first page.
Jan 15, 2009 | Fax Machines
Canon Laser Class 7000 H12013 - need user manual - 'received in memory' on display
we have this machine! all you have to do is hit the green button and they will print out!
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
Changing the text on my fax.
Lift up the cover under the display and press the data registration key, push "set" then scroll down using the arrow keys and look for "user setting" push set, and I think you scroll to the option that says terminal id push set enter your new name and push set again then you can enter your fax number. at any time push the stop key to exit out
Jun 14, 2007 | Canon FAX-L800 Plain Paper Laser
Fax Machines Logo
414 people viewed this question
Top Fax Machines Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Fax Machine Expert? Answer questions, earn points and help others
