Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Electric baseboard heat
How many and what size do I need for an add on room with no other heat source. The room is 172"x 174"
  • 625 Answers
One eight foot unit - 3000 watt high density heater will do the job.
Posted on Nov 15, 2007
I am interested in purchasing baseboard heaters, particularly I have been looking at the Farenheat PHH15002 baseboard heaters. I am purchasing an 1100 square foot 2 story condo with 2 bedrooms and a...
#1 you have to calculate the heatloss of your rooms,that will tell you ur wattage require. Oil filled or not,it's just as dry. As far as ur load to panel breakers, a rule of thumb is approx 3600 watts for 20 amps,using a number 12 wire. But ur wall heaterS should suffice
Apr 21, 2017 | Fahrenheat PHH15002 Oil Filled Baseboard...
Underfloor Radiant Heating for Your New Sunroom
You want to add a brand new sunroom onto your existing house. The problem is that you are not sure how to heat it. Electric heating with baseboard heaters will spoil the look that you want from your new room. Hot water baseboard is going to present all types of problems getting hooked in to the existing system and piping it. And, if you have hot air heating system then you will have the problem of getting ductwork to the room. There is another way to heat this room easily and efficiently.
Radiant heating has been one of the most comfortable and efficient ways for heating for many years. The problem has been in the past to find a good heating source for small radiant floors that will be affordable, effective and efficient.
This problem has been solved now, with the availability of small new electric combination heater- circulator units. These units use small electric heating elements together with a small circulator pump to give you a all in one heating source and circulator pump.
Now you just have to lay your tubing in the floor of the room you are adding on to your house. Then you run that tubing into your existing basement or other room in your house. The tubing and the electric are attached to the heating unit. Then, wire a thermostat to the unit, and you are now ready to make heat. This really makes heating a new addition room very inexpensive and easy to do.
The greatest thing about using this type of heating system is that most average do-it-yourself types can do this. All that is needed is a basic knowledge of plumbing and electric.
If you are thinking of building that little add-on and are worried about how you will heat it, think about using radiant floor heat and a small electric heater-circulator to do your project.
on Dec 05, 2009 | Heating & Cooling
If i have a room 16x24 how big of a electric baseboard heater do
It is not the size of the room that is important it is the heat loss of said room. If it is a inside room, with no outside walls, it will take less btu's to heat and maintain comfort levels, where as if it is a room with floor to ceiling windows, you will obviously need more btu input. Hope this helps.
Mar 03, 2010 | Fahrenheat Electric Convector Baseboard...
How do i know what size baseboard heater to use in any given room.
Basically each baseboard should be rated for a particular heat output...Watts...which should have an equivalent to square footage...look in the Specs or askj the Supplier....and that will vary on the Heat loss of each particular big the windows well insulated the room is etc
Oct 16, 2009 | Fahrenheat Electric Convector Baseboard...
Heater sizing
12000 btu's per 500 square feet is a good rule of thumb
Jul 19, 2009 | Fahrenheat Electric Convector Baseboard...
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Electric baseboard heat not getting hot
Is your fuse box and main power source large enough to handle the full load if all are turned on at the same time? Are you uses two pole breakers? you might only be feeding with 110 volt. This would prevent them from getting very hot.
Jan 03, 2009 | Heating & Cooling
Electric baseboard heaters
measure the room, then multiply the length by the width to get the square feet you want to heat. multiply this by 10 and that is the watts you need to heat the room assuming you are using standard 220/240v baseboards.
Dec 25, 2008 | Marley Electric Hydronic Baseboard Heater,...
Baseboard heaters
measure each room you want to heat. multiply the length x width, this will give you the square footage of the room to be heated, multiply that by 10 and that is the number of watts needed to heat the room using 220/240v baseboards.
Sep 11, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
131 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
