Question about Samsung Digimax S500 Digital Camera
Please help the camera i have is a samsung s500 and it dosen't want to turn on right now. when it worked, i turn it off and the lens didn't close right.that's what caused it to no turn on. i used to make it work by pushing the lens in. but then it did the samething. but now the lens are stuck. and won't turn on.what should i do
  • 31 Answers
In issues like this it helps to have the camera on my workbench where I can test its bits but from your description the problem is likely the servo motor that moves the lens in and out.
When the motor starts to go bad you can still get it to function by pushing on the lens - as you did - but once it freezes the system will stop to function.
Samsung offers service for that camera - you need to follow this link:
Sign up for a service account and then log in, at which point you can begin the process of initiating a service request and contract. You can do this, but the cost of the repair is likely to be higher than the cost of simply replacing the camera, especially when you factor in the shipping and insurance costs both ways.
Your model camera is available on Amazon for as little as $80 and on EBay can be purchased brand new for as little as $107 thru buy it now auctions. YMMV but I suggest replacing it with a new model.
Posted on Nov 15, 2007
I have a samsung S500 and when I turn it on the lens doesn't open or extend and it will beep 3 times and shut off. I have tried new batteries and nothing works. I took it to a camera shop and they
Well, have you ever considered that the lenses MIGHT be defected? If it's true, you can send it back to the manufacturer, as long as it wasn't YOU who made it defected.
Another tip, is maybe the lens isn't made for that type of camera.
Lastly, the lens can just be broken, so you should carefully examine it, and see INSIDE of it, to make sure all of the parts are their. Hope this helps (:
Jun 11, 2012 | Samsung Digimax S500 Digital Camera
Not working at all
So i was having the same probelm with my camera and after some researching I found out that its a lens probelm. Some people in some forums had said to turn the camera and put a towel around the lens and try to push the lens back in. I thought what the heck it sounds crazy but it can't be any worse than where I'm at now. So I did it and it worked! The camera actually turned on and no more beeps!!! YAY! The only thing is the zoom no longer works on it so I am going to try to push on the lens a little more I guess. I will update when I find out more. Let me know if any of you try this and if it worked for you!
Feb 14, 2009 | Samsung Digimax S500 Digital Camera
Camera turns off when shutter button is pressed.
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
Sep 20, 2017 | Samsung Digimax S500 Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
When I try to turn on my camera (Samsung Digimax S500), it beeps 3 times.
My Samsung S500 kept shutting down (with lens extended but no beeping) as soon as it was turned on. After reading similar problems being caused by a jammed lens mechanism, I GENTLY twisted & tugged the extended lens mechanism (no crude comments please), and it worked the next time it was turned on.
Apr 20, 2008 | Samsung Cameras
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
S5oo Digi Cam , The camera does not power on .
i dropped mine.
and the lens was stuck and it made those sounds.
we messed around with it
and kept opening and closing it.
and after about it an hour.
it just started working again.
Nov 10, 2007 | Samsung Digimax S500 Digital Camera
Frozen camera
your lense is jammed try to put your finger in it and close the lense all the way it might me like hardly closed, i had that problem and now my is open all the way so i cant close it yuo can email me at or im makaluso06
Jan 26, 2007 | Samsung Digimax S500 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
41 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
