Question about Sportsart 6200 Treadmill
Cuts out when set to go uphill - Sportsart 6200 Treadmill
Could be a couple of things, I have found that alot of the time it is the belt or deck wearing out and the added effort of uphill causes overcurrent and trips the circuit to protect it from damage. Run your hand between the belt and deck and feel how smooth it is.
Posted on Jul 12, 2009
Power lose when cutting uphill
most of the time when a mower wont pull uphill it is because the drive belt is worn to the point that it slips. check and replace it. should be as good as new.
Jun 02, 2018 | Garden
Hi, I have an Opel Monza, 1.8 GLE 1987 model with carburetor. When accelerating uphill, it drops revs and wants to cut out or just cuts out and I battle to start it. It also jerks a bit when I drive i
hi Yvette! from what you are describingi think thats the fuel pump that is going to die very soon to your hands.i suggest if your mechanic has a spare one to replace it and make some test runs himself,before he delivers it to you!
Feb 05, 2014 | Cars & Trucks
Cutting out
The proper diagnosis would be to get your car to your dealership whom can help you out a little more better.
Jan 30, 2014 | 1993 Buick Park Avenue
Have a 2000 500 quad will start run up but under load it cuts out. runs fine on the flats. when you want to go up hill the engine has no power. could the cam be worn out? in neutral you excelerate it...
Intake at .006 and exhaust at .010 Adjusting needle to sit lower setting leans out your mixture-be careful lean mixtures cause excessive exhaust temps and a huge temperature gradient across your piston crown causing a locked up motor. What does your spark plug look like after riding? this will be a good indicator of how lean or rich you are. black and sooty is rich, caramel is just right, and white or ashy is lean - BAD. Any machine that backfires has either a timing issue, or a valve adjustment issue. You sound mechanically inclined, so double check your clearances. Also, since you mentioned the uphill issue, it could simply be that your fuel level in the carb bowl is just right on the flats, but as you point uphill, it is not right anymore. . .the fuel runs to the back of the carb and cannot be drawn into the main jet because it's not there anymore.
Nov 23, 2010 | 2002 Yamaha YZ 426 F
2000 Chevy Trailblazer will not start when parked uphill. When it does run there are no problems when driving uphill. Engine turns over initially but immediately cuts out then just cranks with to no avail....
Solution was the Fuel Pump Relay. For this problem listen to the car as you turn the key forward just before cranking the engine. You SHOULD hear a buzz/hum that lasts for 2-3 seconds. This is the fuel pump relay priming. When the car was pointed uphill without a functioning relay there would be an air bubble in the line thus no turn over.
Nov 16, 2009 | 2000 Chevrolet Blazer
When it goes uphill it cuts out and dies but
There isn't enough gas in the float bowl to cover the jets when the carburburator is tipped. If it's been rebuilt recently the float wasn't set right or if it hasn't been rebuilt, it's probably time because sediment is starting to build up in there. Hope thishelps.
Oct 17, 2009 | 1983 Chevrolet C3500
22.5 kohler wont pull uphill.
not a expert just trying to help,, here is one thing to check,, check your drive belt to see if it is worn if so it maybe slipping,,hope this help
Oct 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Sep 29, 2009 | Garden
Sportsart 6200 Treadmill Logo
70 people viewed this question
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven Brandon
Steven Brandon
GymWorld
GymWorld
Level 1 Expert
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
