Linksys WRK54G versus WRT54G Firmware
I have a Linksys WRK54G that isn't being used, but I need a wireless access point/range extender/repeater. I believe the WRT54G will serve as an access point, but will the WRK54G do the same? Or should I forget going this route and just buy a dedicated range extender?
Any ideas that would help me make a decision?
  • 1 more comment
  • cebookseller Nov 16, 2007
    We ended up buying a Belkin Universal Range Extender because we needed to get things up and running quickly. I still haven't given up on using the WRK54G, but it's not priority just now. Here's a clarification: "From what you say in your question I gather that you have a WRT54G already in place..." No, I do not. I just wanted to try using the WRK54G in place of buying the Belkin. The Belkin is working great, but there was a glitch or two getting it set up. My 18 year old son figured it out for me and he's the expert.
    Thanks.
  • cebookseller Dec 14, 2007
    I was not able to use the WRK54G as a repeater. I ended up purchasing a Belkin Universal Range Extender and it's a work-horse. It's doing exactly what we needed for it to do.
  • fadefdas Aug 15, 2008
    Access Point bought out door level one wap-1001 was Chgalh
    But it was a short-range knowing it 12 dpi and dedicated it to give up Mde
    To 30 kilometres I did shredders Rio Kirgen modern and misfortune that they were disrupted
    1 - when Balraur or computer network through the cable network relate to a 15-second and then automatically separated
    Relate to and separated again Thus
    2 - for people who send a signal Irles
    Scholar:
  • 31 Answers
Hi...
The WRK54G is actually a stripped down version of the WRT54G that was bundled with a wireless network adapter and sold under the kit name WKPC54G.
From what you say in your question I gather that you have a WRT54G already in place as your access point, and it is what is connected to your WAN. To use the WRK54G as a range extender repeater you should do the following:
1. Turn off DHCP
2. Turn off NAT
3. Assign a fixed IP that is in your Class C Block
4. Define the WRT54G as the Gateway
With this configuration it now should function as an extender/repeater, and any clients connecting to it will be serviced by the DHCP on the master router.
I hope that this helps.
Posted on Nov 15, 2007
#2, you set your gateway under the Static IP option, when you are setting off DHCP. You'll need your new IP, Gateway, and a DNS addrss.
Posted on Mar 28, 2008
I am doing something similar here - have steps one to 3 done - but where do i set the gateway as the first router in the second router options
Posted on Dec 13, 2007
Dear Recnef,
Your help information looks promising. I am not using a WRT54G as my access point (router). The router is a Netopia. I don't know the model number of the Netopia. I'll have an opportunity today to experiment with the Netopia. I'll try the settings you gave me and see what happens. Will let you know what happens.
Thanks so much for your help so far.
Daisychan linksys extender 1000
I don't think it is possible.For reasons too technical for this forum, the extender does not have the ability to connect to another extender. You could try using an Access Point or router capable of working as an access point as the first extender, then using the RE 1000 to extend from that.
Mar 10, 2014 | Linksys RE 1000 Wireless-N Range Extender
IS CISCO LINSYS WAP-610 AN AP REPEATER Range extender?
You cannot use the WAP610N in repeater mode unless you connect it to your router using a cable.
Dec 14, 2010 | Linksys by Cisco WAP610N Wireless-N Access...
I am trying to hook up a omni antenna to a wrt54g is it possible in a motel setting
Hi there If u have a linksys wrt54g router. the omni antena will not give u the maximum wireless signal if u are going to set it on a motel, u need to setup a wireless access point in order to broadcast the signal or to repeat the signal u need a wireless access point and the model # is WAP54G..
here is the link just incase u want to know more about on how to set up a wireless access point
1. How do I configure an access point as a wireless bridge?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4194
2. How do I configure an access point as a wireless repeater?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4200
3. How do I configure an access point as an access point client?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4202
4. How will I know if an Access Point is configured as an Access Point?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4165..
check this out and i hope this will solve ur concern..
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
WRK54G as a repeter
Okay, if it is a wireless repeater, you simply cannot, the WRK does not have such capabilities, but WIRED, that may work.
By default the routers IP is 192.168.1.1, so turn off the DHCP of the WRK, then change the IP to 192.168.1.something else. for the cable routings, from the primary router's ethernet cable should be plugged in to any LAN port of the 2nd router.
then you can relocate the 2nd router to where it has to be as long as the cable reaches it (not longer than 200 feet)
for the wireless settings, just make a different wireless networks for both routers.
if you have other questions just lemme know
Nov 02, 2008 | Linksys Wireless-G WRT54G Router
WAP54G's as repeaters
Are you trying to setup both access point to repeat the signal of the router?
The correct way to setup the AP's as repeater is to access the setup page of your router go to status and go to the wireless subtab, check what is the MAC address that is what your suppose to configure on the AP's not the LAN MAC address which is on the local networks subtab on status.
Access the setup page of the AP's and go to AP Mode, make sure that you choose the repeater and copy down the Wireless MAC address you obtained from the wireless router. To enable roaming, meaning your wireless computer/device will connect to the AP/router closest to its location, change the wireless channel on all three device for example WRT54G will be on channel 1, 1st AP as repeater on Channel 6 and the last AP to Channel 11 but the other settings must be the same(Wireless name(SSID) and Wireless Security).
Note: Setting up an AP as repeater to repeat or extend the signal of another AP that is set to repeater is not recommended since the signal will deteriorate due to the number of hops the packets will be sent.
Hope this will help you setting up those WAP's which for me is quite useful since you can set it up to act as a repeater, AP client and a bridge to a WRT54G router.
Regards,
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
Need help setting up an syslink G access point?
You could install the dd-wrt firmware, which gives you the option of being a repeating station. See www.dd-wrt.com for all the details.
With factory firmware, you must use a cable.
Jun 20, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
How to use second access point as repeater
pls i also need solution to this problem, kindly send to my email akinomatics@yahoo.com
thanks
Feb 12, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
Setting up a WAP54G as a wireless repeater with a WRT54G
Requirements for WAP54G & WRT54G Repeater Mode function: * WRT54G: Firmware 2.02.2 or higher * WAP54G: Firmware 2.06 or higher Go to http://www.linksys.com/download to download the latest firmware upgrades for both devices. . Accessing the Router?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the Router into the Address Bar (192.168.1.1 is the default IP Address). 2. Click GO or press the [Enter] key. The User Name and Password prompt will appear. 1. Leave the User Name field blank. 2. Type admin in for the Password (the default Password). 3. Click OK or press the Enter key. The Router?s Setup page will open: * Click on the Status Tab. * Click on the Wireless sub tab. Write down the Wireless MAC Address and the Channel number values located on this page. If the Encryption Function is Disabled, go to the WAP54G Repeater Setup section below. If Encryption Function is Enabled: Note: WPA (Wi-Fi Protected Access) is not yet compatible with wireless repeater mode. You must use WEP Encryption if you wish to use security options with this configuration. To gather WEP encryption information, click on the upper Wireless tab, then the Wireless Security sub tab. Write down the Passphrase. WAP54G Repeater Setup Be sure that you have the WAP54G plugged directly into one of the WRT54G?s numbered ports for the duration of the setup. Accessing the WAP54G?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the WAP54G into the Address Bar (192.168.1.245 is the default IP address). 2. Click GO or press the Enter key. 3. The User Name and Password prompt will appear. 4. Leave the User Name blank. 5. Type in admin for the Password (the default password). 6. Click OK or press the [Enter] key. The WAP54G?s Setup page will open. 1. Set the Channel value to the same channel as the WRT54G router that was obtained from earlier steps. 2. If WEP encryption was enabled on the WRT54G: * Select Enable for the Wireless Security option. * Click on the Edit Security Settings button and enter the same Passphrase as the one of the WRT54G router that you recorded. Click Generate to populate the WEP key fields. * Click Save Settings to save your changes and close the encryption window. Click Save Settings to save your changes on the Setup page. 3. Next, click on the AP Mode tab. * Select the Wireless Repeater option. * Enter the WIRELESS Mac Address from the WRT54G that you recorded. (Disregard the fact that the page asks to ?Enter the LAN MAC ADDRESS?). Click Save Settings to save your changes. Close your web browser. You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G. Notes: * The ?SSID? of the WAP54G does not have to be the same as the WRT54G. This can be used for initial configuration; using a different SSID will enable testing of network connectivity, and will show that the WRT54G is associated with the WAP54G. * If MAC Filtering is configured on the WRT54G, no extra configuration is needed. Wireless clients will still need to be added the MAC Filter list of the WRT54G, but the WAP54G does not have to on the list.
Computers & Internet Logo
6,107 people viewed this question
David Payne
David Payne
