Question about Cell Phones
Voyager VX1000 Boots then internal screen goes blank
My Verizon Voyager powers on and displays the normal Verizon logo and display on internal screen then it goes blank. External screen works fine and all other functions seem to work fine. I have tried removing the battery for several hours but it still goes blank after boot up.
Hi, I have a 2006 650i The display unit intermittenly goes blank shutting off the radio etc just leaving the BMW logo showing, then after about 10 minuets returns to normal
Short to power. Could be as easy as just pulling a fuse and reinsert it. Sometimes you have to access the plug and do they same thing. Sometimes you have to fix or replace the plug. If your display is the radio, It could be internal radio problems..
May 28, 2016 | BMW Cars & Trucks
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
Voyager phone external screen is blank. When powering up Verizon logo comes on and then it goes blank
Need more info...
Can you see the power and antenna strength bars before it blacks out?
Leave it to charge for at least a half hour before trying it again.
Leave it on the charger while you're trying. Try another charger/outlet.
Remove the battery for a minute or three and then put it back together and try again.
Further suggestions would depend on results and any other symptoms.
Dec 18, 2010 | LG VOYAGER VX10000 Cellular Phone
After 3.5 weeks of operation, I looked at the screen after being away from the computer, and it was blank. I smelled burning resistor/electronics. Rebooting results in Windows XP displaying the logo and...
I would check your power supply with a meter to see if that's the problem. If it checks out ok then it's probably the mobo. In rare instances when a power supply goes it takes the mobo with it.
Best of luck...Hank
Feb 02, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
LG Voyager won't reboot
Interesting, normally the screen only appears with water damage, which I am sure Verizons customer service has continued to tell you that is the cause without thinking the customer might not know for themselves, The only way to fix this is to got to a Verizon Wireless store and ask them to do what is called a software flash, now it may delete all your information on your device but at least it will work, if you need any more help with this let me know.
Jan 02, 2009 | LG VOYAGER VX10000 Cellular Phone
Acer estensa 5620
Might be something wrong with your display settings. Between the Acer logo and Microsoft logo, try pressing F8 about twice per second. A menu appears. Use the arrow keys and choose the one with "VGA-mode" using the enter-key. Wait while the computer boots. Set a compatible display resolution for your display.
Nov 03, 2008 | Acer Aspire 5610 Notebook
Cell Phones Logo
154 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
