Question about Nintendo DS Console
Stylus tip stuck in headphone jack(no sound!)
Stylus tip stuck in headphone jack and hence sound is muted. Is there a way to open the shell to get this out?
    An expert whose answer gotĀ voted for 100 times.
  • Nintendo Expert
  • 127 Answers
Re: stylus tip stuck in headphone jack(no sound!)
Yes, here is a guide to dismantle an original Nintendo DS:
How to dismantle a Nintendo DS.
If yours is the NDS Lite, just find this video in youtube:
"Disassembling Nintendo DS Lite"
And after opening it you may need to replace or try to repair the audio plug. In case you cant, then you must take it out (desoldering it with the stuck stylus tip and the mute switch, which is embeded in the headphone jack) and you can have your audio back.
As the audio switch and the jack only work to mute the speakers audio usually when you plug a headphone then you can lack of it almost all times.
Posted on Nov 16, 2007
Hey.. i just bought a pre owned nintendo ds game.. and its stuck! i cant get it back out! iv been playing the game tho n it works fine... any1 know a way i can get it out or what might b causing it to stay stuck in there?
Posted on Mar 09, 2008
0 characters
3 Points
No sound at all
Do you have sound at all? If you have none sound try plugging in headphones and see if you have sound there. If you do and you can increase and decrease the volume then it is a problem with the internal speakers of the headphone jack. (May need to clean it by cutting the end off a q-tip and jamming it in and out.
Nov 18, 2013 | Nintendo DSi Matte Blue Console
go to radioshack or some other electronics repair shop, and get an 1/8 inch stereo headphone jack. now you have to open the case of the PSP, an look at the main circuit board. undo the 4 or 5 solder joints in the main vicinity of the Old Jack. once the jack is loose, take it out and replace it with the new one in the exact same place. Now carefully re solder all of the joints being careful not to get any solder on the board, as this will ruin the entire system. Now close everything back up, and you should be good to go.
Feb 21, 2008 | Sony PlayStation Portable (PSP) Console
My dsi has no sound at all
It could be either internal speaker damage, internal circuit damabe or problems with the headphone jack. Try plugging in headphones if you have sound then you have no internal circuit damage. Try cleaning the headphone port with a cut off Q-tip. Also sit it in a warm dry place for a few days. If the sound still does not work the speakers may need to be replaced.
Nov 18, 2013 | Nintendo DS Video Game Consoles
Leapster 2 has no sound
We got our daughter a Leapster2 for Chrstmas 08. One day the sound just stopped working. Called Leapfrog. They said to insert a cartridge, and turn the unit on. Plug headphones into the headphone jack. Then rotate the headphone plug-in 360 degrees,( It is easier to hold the heaphone plug-in and rotate the leapster2). Unplug the headphones and check to see if the sound works. Leapfrog said try it more than once, and if it does not work contact them,1-800-701-5327. We tried it and Hallelujah it worked!
Feb 15, 2009 | Nintendo Game Boy Advance Console
Psp sound problem
My son had the same problem. I put tape around the top part of the headphone jack and plugged it in. Worked great!!! Don't know how long it'll hold up, but it's a quick fix for now.....
Nov 25, 2008 | Sony PlayStation Portable (PSP) Console
No sound from psp-1000, not even from headphones, and not in mute mode.
well buddy i think your gonna hae to get technical and open up your psp take all of the stuff off until you get to the motherboard and check the speakers.
Sep 13, 2008 | Video Game Consoles
The vol. is not working on my psp
Make sure the volume is not set to zero. Try raising the volume using the volume buttons located on the front of the PSP.
Make sure the mute setting is not on. Press the (Music Note), third one from the right, located on the front of the PSP® to clear the mute setting.
If headphones are inserted, the PSP will not send any sound through the speakers. To check that the speakers work, unplug the headphones.
Hope that will Fix Ya!
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
Need new headphone jack
I may have one to sell you. I have two nonfunctioning DS lite motherboards that I can remove the headphone jack from. Cost would be $8 plus $7.99 for shipping/handling. I can cut it off the motherboard and send it. Do you have the tools to open the DS up and solder a replacement on? If not, I would do that for you at $40 plus $7.99 shipping handling. E-mail
Jul 08, 2008 | Nintendo DS Lite Console
My sound is all wacked
well something might be stuck in the psp and thepsp might think its headfones and wont make the sound go outloud.see if ther is anything in the psp souund hole wer the sound plug is
Feb 23, 2008 | Sony PlayStation Portable (PSP) Console
My sega game gear sound has no sound how can i fix it!
might need a new headphone jack due to rough handling or a new volume pot. try plugging in headphones and wriggling them gently to see if you get sound, if that does not work try fiddling the volume knob, whichever gives a burst of sound will show you which needs to be replaced.
Feb 13, 2008 | Sega Game Gear Console
Nintendo DS Console Logo
1,321 people viewed this question
Top Nintendo Video Game Consoles Experts
Troy Gorman
Troy Gorman
Paul Layton
Level 1 Expert
Are you a Nintendo Video Game Console Expert? Answer questions, earn points and help others
