Need to know how to load ink cartridge - Office Equipment & Supplies
    Guru:
  • 829 Answers
Kindly let me know which Printer you need to load the ink
Posted on Jul 11, 2009
I NEED TO KNOW HOW TO LOAD INK CARTRIDGES IT
The Lexmark 7100 Series User's Guide will give you a more comprehensive guide on how to load your ink cartridges in your printer.
Aug 28, 2011 | Lexmark X7170 All-In-One InkJet Printer
My printer won't align new ink. It says load paper in tray. I load it. then blank page come out and gives me the same message. Load paper in tray. I did a diagnostic test and at the bottom it says...
Sorry to know you're in trouble with your printer. Here are my suggestions: You have to buy a new genuine cartridge or you can refill ink. Be warned! Refilling ink or using a refilled ink cartridges will not work until the ink cartridge chip or ink monitor is disabled. For instructions on how to disable an ink cartridge chip, please visit [http://www.ehow.com/how_6201242_disable-ink-cartridge-chip.html]Now you can CURSE the manufacturer of your printer for making your life sucks by making it complicated the things that should be made SIMPLE and EASY. Printer or Cartridge, more or less, cost you the same. Don't you think the printer cartridges should be made simply refillable/usable unless they are broken, and we should be buying only the ink for the cartridges. It is SO ANNOYING, dude! Good luck.
May 06, 2011 | Office Equipment & Supplies
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
5. Plug the printer back to the power source.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
The paper doesnt load and do i need both ink cartridges to work cuz i only have one installed
Some printers -- most printers -- require both ink cartridges to work. If you have both but one is empty, you might be able to put back the empty one. Sometimes, you can trick the printer into thinking that it has the fluid when it does not. I don't know the 924 specifically to tell you if you can get away without ink in the second cartridge.
May 16, 2010 | Dell 924 All-in-One InkJet Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
  2. Lift the front cover.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Open Questions:
My Ricoh 3035 / Savin 8035 prints uniformly light pages, and tells me to add toner, with a FULL toner bottle. The developer unit itself is completely packed with toner. There are no other errors set. The issue described is recent, within the last 500 copies. Prior to that this machine was running perfectly. I've had this copier for a couple of years. It was used. It NOW has 617,871 prints/copies/faxes as of today. I replaced the developer unit remanufactured and new developer at 591,810. The transfer belt and cleaning blade are new at 607,638. I replaced the PCU with a completely remanufactured unit at 607,688. The fuser was replaced with remanufactured unit also at 607,688. I was STILL having some issues with bad quality copies, so I narrowed the matter down to a defective drum in the remanufactured PCU. I replaced the drum, and at THAT time, I installed every part in the Savin Maintenance Kit PMB082150K, which I previously received with the copier. I also replaced the PCU Entrance Seal and tape the long mylar one at the top of the drum. When I installed the developer unit, I initialized the settings, pursuant to the Service Manual, and the same with the drum, and the appropriate one each time I previously cleaned the ID Sensor Today, I went through the trouble of replacing the ID Sensor, initialized the same, and it made no difference. The copier has run just fine for the last couple of months, and then as I stated in the question, about 500 copies ago, all of the copies suddenly became light. No, it's not the density setting. I've done everything except do a factory reset. Incidentally, I have the Ricoh 3035 Service Manual, and also the Parts Manual. Experientially, the only computers I have ever purchased are 2 of them, for my office, in 10 years. Other than that, I have built every computer I've ever made, from parts. As far as this copier, I have done the copier maintenance, per the maintenance schedule, myself, and when it appears that maintenance needs to be done. This problem however, is driving me nuts. As I said, the only symptoms of the light copies are that add toner light that comes on periodically, and toner absolutely packed into the developer unit entrance such that its spills out when I remove the PCU. One last thing, and this is an when all else fails kind of thing: since the toner bottle is full, I open the front door, and using a channellock, I fix the add toner problem by rapping very lightly on the end of the PCU, and the developer unit! This DOES fix the toner out problem every time, but it does NOT fix the light copies. Simply opening the door, sliding the toner carrier out, putting it back, and then closing the door, and repeating that process a couple of times sometimes also works.
Jan 21, 2019 | Ricoh Aficio 3035 Digital...
77 people viewed this question
k24674
Marvin
Marvin
