Question about Refrigerators
The food in the refrigerator is not cold, things in the freezer are beginning to thaw. Ice maker and dispenser are working fine
  • marilyngiffo Jul 11, 2009
    there are no clicking sounds in the refrigerator or freezer
    President:
  • Refrigerators Master
  • 1,730 Answers
It's very possible that your iced up inside on the evaporator coil. This is usually caused by the defrost timer. You could try defrosting it for 24 hours yourself then put your foods back and turn it back on. If it works correctly, the defrost timer is not working.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 11, 2009
  • 1,170 Answers
If there is a clicking sound then the problem is your relay compressor is bad,you can replace with same relay and overload or you can try a 3-n-1 hard to start for ref. compressors.
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The water dispenser has stopped working. It is getting power. When you press the button you can hear the motor. The ice maker is still working fine so I know the unit is getting water.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer while it thaws.
Aug 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice make is not working New water filter as of yesterday, it dispenses water fine for drinking but does not dispense water for ice Model #RS2556RS
This could be a frozen water line that feeds the ice maker. Turn the temperature down on both the freezer and the refridgerator and wait at least 48 hours for the temps to adjust and thaw the line. If you are in a hurry you could turn off the unit and remove all food and then use a hair dryer on the water line to thaw it out. Good luck!
May 25, 2010 | Samsung RS2556 Side by Side Refrigerator
Ice maker not making ice.
TRY DISCONNECTING THE ICE MAKER FROM INSIDE AND RUN HOT WATER OVER IT UN TIL IT IS COMPLETELY THAWED, THEN RECONNECT IT AND SEE IF IT WILL MAKE ICE NOW. SOMETIMES ICE MAKERS CAN BECOMED BLOCKED BY ICE.
Apr 12, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
The water is leaking from the Ice dispenser and the food is thawing
Seems like the freezer is not getting cold enough. If the ice maker was leaking the water would freeze. It would not cause the food to thaw.
Oct 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Oct 18, 2007 | KitchenAid Superba 21.6 cu. ft. Top...
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
