Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
In replacing push button switch INDAK 681064-01N I forgot to record the wiring sequence, please help
If you look at the switch with the pushbutton on the top, the white wire from the cord to the motor attaches to the upper left terminal, the red wire from the cord to the motor attaches to the lower left terminal (just below where the white wire attaches), the black wire from the cord to the motor attaches to the upper right terminal and the short black wire going to one of the two pins that plug into the extension cord attaches to the lower right terminal (just below the where the black wire to the motor cord attaches).
Posted on Jul 27, 2009
  • Peter Schommelman Oct 19, 2011
    Dear Lynn, searching on the net I found your answer above. I have the same problem as jtingley, but have to many wires for what you describe in your answer. I have red, blue, green, black and white coming from the motor. And a black and white wire coming from the power cord.
    I still have an old 4 prong Indak 681064-01 switch (don't know for sure if this came off this machine) and I also have a new 6 prong Carling switch.
    Please can you help me?
Cub cadet starter engages as soon as you turn switch
It is the wrong key switch or the switch has gone bad. Inside the switch there is two round disk facing ech other, on them disk there is flat brass buttons, as you turn the key it touches them in to each other in a set order. so in the start position it connects the battery wire to the solenoid wire to spin the engine.It also ungrounds the wire to the coil Of course it goes through a bunch of safety switches getting there. I think there must be 50 to 100 different indak switches that look identical but the wires are in different order. So if there was two on the bench I would say you picked up the wrong one.
Mar 18, 2016 | Cub Cadet Garden
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
Sharp microwave model R7704 replace the fuse came on start humming and went out again what could the problem be
Robert, you have a short somewhere in the electrical system and that is why it keeps blowing the fuse. Many times, I have found that one of the micro-switches connected to the door opening are the culprit to the short. You would need access to a multi-meter that can measure continuity to be able to check them. Some microwaves are more difficult than others to access those micro-switches and you will need to be able to pull the wires off of the switches to get an accurate reading. If you decide to try this yourself, either take a picture of the wiring before you remove any wires or at least write down a good description of the wiring. You might use some masking tape and put a small piece around each wire and number them in sequence and write that down so that you make sure to re-wire the switches properly. Each of the switches are going to be a normally open or normally closed switch and one of them may have a bad internal connection and you may have no reading at all or have the same reading no matter which way the button is pushed. You will have to push the button on the switch to activate the switch to get your reading. A normally open switch will have no reading until you push the button. A normally closed switch should always have a reading until you push the button. If you have no reading or a constant reading or if the button will not push, that switch is going to be your problem. Replace that switch and put everything back together and that should take care of your problem. Hope this helps!
Feb 04, 2015 | Sharp Microwave Ovens
Machine will not start, replaced start switch now machine starts with the hot and warm button i think i have got my wires crossed
the start switch will just have a hot wire,, with a momentary closing when you push the start switch,, if you list the make and model of your machine, I'll try and find the wiring sequence for you
Jun 30, 2011 | Dryers
My remote is fine, but i don't know which button to push or sequence once I've changed batteries to for it to work the receiver. Each time I change the batteries it doesn't interact with the receiver, but...
It's likely that you've pressed one of the input mode buttons accidentally while changing the batteries. You've probably switched the remote for operation of a TV or DVD player or some other device.
To correct this problem, simply press the RECEIVER (TAPE/AMP) button once, then try the remote again. Pressing this button informs the remote that you wish to operate the receiver with it again. The RECEIVER button is about halfway down the left-hand side, above the TV button and below MACRO 1.
Please try this first. If the receiver still does not respond, switch the receiver off and back on again. It may have lost the communication with the remote. Resetting the receiver will usually correct this problem.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Feb 26, 2011 | Onkyo TX-SR703 Receiver
I have problem with my pd 170 when i push recording switch it gos on paus mood
There are three buttons for recording. Please try the other two buttons ( one is on the top, other is under the handle) if the recording starts with any of the buttons, then your main button will be faulty. You have to get it replaced.
Hope it helps. Don't forget to rate me.
Thanks for using FixYa.
Jan 15, 2011 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Is the button NC or NO? I have it currently wired this way but still it does not work and I'm using a switch not a button. Any suggestion?
The switch is OFF or NO normally open
See wiring diagram at following link
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
The way the timer works is this::
You click switch ON
When you turn switch OFF, the Dayton begins the timing sequence
The Dayton turns on the circuit going to load for 1/2 second => 5 minutes depending on model of Dayton timer
Grainger sells 120V push buttons if you don't want to turn the switch on-and-off each time
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=push+button+switch&op=search&Ntt=push+button+switch&N=0&sst=subset
http://www.grainger.com/Grainger/IDEAL-Push-Button-1XWT9?Pid=search
Oct 12, 2010 | Amperite Dayton Solid State Timer On Delay...
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
Dishwasher won't stop running
OK,, this seems to be a control fault. this is usually fixed by unplugging for 5 minutes and resetting the control.
as you stated, you have done this reset and the issue is still a problem at this point. this basically confirms the control fault within the control assembly and sequence switch.
This is easily fixed by replacing the Control assembly and sequence switch. the affected parts and their respective part numbers are listed below.
Control assembly ----- Part number # WD21X10116 $148.75
Sequence Switch ----- Part Number # WD21X10018 $99.75
this will fix your dishwasher.
Please rate and god bless:)
Apr 28, 2009 | Dishwashers
Need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Apr 10, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
1,218 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
