Question about Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point
How do I make a secure wireless network
I have a SBG900 wireless SURFboard Gateway modem and I want to make it a secure network.
    President:
  • 623 Answers
If you don't have the manual, you can download it here.
Look at the chapter "Setting Up Your Wireless LAN" (page 64).
Then follow the guide for "Configuring WPA on the SBG900" (page 66).
Try to avoid WEP, since it is easily hackable and only gives the sense of false security. As encryption, choose WPA AES, because it is more secure than TKIP. WPA Authentication should be "local", since you don't want to run a dedicated server.
Some older laptops cannot deal with WPA-AES. In that case you have to fall back to WEP, but try WPA first.
Furthermore you should change the ESSID from "Motorola" to something more specific for you, so other clients don't connect accidentally to your network (page 71).
If you want to enable MAC filtering is up to you and only makes sense if you never have friends or colleagues coming over with a laptop. I would leave it off and enable it at a later point, after you see that everything is running fine.
Don't forget to set up your computers as well! You have to provide the passphrase for them, otherwise they can't connect (see page 75). The way I do it is to create a strong (!) passphrase like "V0y6Mmb90y...", copy it into a text document (use notepad), and save it on a USB stick. form there you can copy it to the field, when Windows (or Mac) asks for the network key.
No typos = no headaches.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jul 11, 2009
I FORGOT WHERE TO FIND THE PASSWORD FOR MY WIRELESS TO HOOKM UP MY PS3
you must browse your router and go to the security section under wireless configuration. see page 87 of (http://www.motorola.com/staticfiles/Support/US-EN/Home-and-Office/Cable-Modems-and-Gateways/SBG900-SURFboard-Wireless-Cable-Modem-Gateway/Documents/Static-Files/SBG900_User_Guide.pdf) for screen shots of where to look.
and remeber a PS3 need to have broadcast of ssid turned on for the intial setup.
GL
hope this helps
Don't forget to vote for me
TY
Jammer
May 27, 2011 | Arris SURFboard SBG900 Wireless Router...
My computer dosen't read my wireless surfboard sbg900
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Apr 06, 2011 | Arris SURFboard SBG900 (49402201900) Modem
Is the Motorola SBG900 cable modem gateway a router- that is will it enable file sharing between the computers that share the gateway (one wired, one wireless). If so how is this set up?
you should be able to set up a home network you will have to enable file sharing, if you run through the network setup wizzard in the control pannel it should be fairly straightforward
Jan 21, 2011 | Arris Surfboard SBG900 Modem Cable Modem...
How to set up password
insert the disc supplied by your ISP internet service provider then enter the the user name and password you provided to your intenet service provider ISP then just follow the prompts
hope this helps
Dec 22, 2010 | Arris Surfboard SBG900 Modem Cable Modem...
I have a Motorola surfboard want to create wireless network
Should do it during set-up. More than likely you are having a problem because the modem comes pre-configured with wireless security enabled. Use the WPA-PSK code found on the label on the bottom of the router/modem or on the extra labels.
May 12, 2010 | Arris SURFboard SBG900 802.11g/b...
Weak signal thorugh my sbg 900 wireless surfboard gateway
On the Wireless > SECURITY — basic Page check whether the WPA Encryption type is TKIP.
If all of your wireless clients support AES, change the WPA Encryption to AES. This may make a difference for you.
Jan 03, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Motorola modem SBG900
you must define DNS and Gateway!!! Go on My Network Places, right click, again right click on your network, select properties, TCP/IP and in there enter needed IP addresses!!!
Jan 25, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point Logo
1,056 people viewed this question
Top Arris Computers & Internet Experts
Greg Ulan
Robbie Goodwin
RS Technology...
RS Technology...
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
