Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Philips 37PF7321D LCD TV
I purchased this set as part of a liquidation lot, as the protective glass front was shattered. The TV functioned perfectly, but cosmetically, it was a mess. I removed the remains of the shattered glass, and now when I plug the TV in, it clicks on and off continually. It does not respond to the power button or remote. Just clicks on, clicks off... Again, and again and again until I unplug it. Any suggestions? It worked fine one day, and kaput the next... The set is brand new, as it still has all the protective tape etc where the mfr had put it for packaging...
  • andrewkl Jan 01, 2008
    a wire to the PS was crimped, causing the problem.. It's since been corrected. Thanks!
  • 106 Answers
Try to replace the power supply board of your tv.
Posted on Jan 01, 2008
How to replace front glass on this unit
I need the model of your phone to find you a guide. A guide may not have been made for that device, but If not, I can find you a guide where the build and dissembly are identical. (Standard breakdown . remove battery cover. Battery, sim card, SD card, remove screws plastic cover. Use a guitar pick/opening tool to run along the seam to split plastic case. From here. Remove any metal shields (if any) to disconnect all connectors. Such as LCD cameras mic , vol buttons etc. Once freed of connectors remove screws holding logic board down. From here you should be holding a front "clip" just glass. LCD. And digitizer. Depending on your part.if its a complete front clip. The just follow steps in reverse on new front clip. If it's just the glass. You will need a hair dryer or heat gun to heat up glass and make adhesive loose enough to separate the glass from the frame. Once separated . follow steps in reverse. Take lots of pics during disassemble to remember location and order )
Sep 07, 2015 | Blue BLU Studio 5.5 D610A JB 4.2 Android...
A Philips 37PF7321D TV, no picture. Powers on, audio works, input switching works. Got picture once (menu and signal) clear, bright and good color. No blinking red lights. What to check or test next?
Looks like you have done a lot of testing. Try Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Feb 26, 2015 | Philips Televison & Video
Picture tube is discolored almost like a shattered glass appearance?
That shattered looking glass effect is your LCD panel shattered. Your panel needs to be replaced. Would be more cost effective to replace your TV.
May 12, 2011 | Vizio L32 32 in. LCD HDTV
Both the front glass and dark glass right behind the front glass are shattered....assuming this is the extent of damage, can these be replaced and for how much? The tv is 42PF9630A
In my somewhat admittedly limited experience, the replacement of any display screen, plasma or LCD, the cost exceeds the price of a new set.
Mar 30, 2011 | Philips 42PF9630A 42 in. Plasma Television
HELP!!!! - Vizio GV47LF LCD HDTV HELP!!! - HOW TO FIX?
When you turn it in, do you get an image? And if it is the LCD screen ( not the front protected glass) then yeah you might as well junk the TV. The cost for a replacement LCD screen exceed the cost of the unit. Sorry about the bad news, just being honest. Turn the television, if the LCD is cracked, then you will see it right away when the television is turned on.
Nov 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
Battery gets hot and won't hold a charge; plus shattered LCD screen
the glass and LCD can be fix and replaced but the main-board heating up is saying that the board needs to be replaced but you should just purchase new one.
Jun 26, 2008 | Motorola Mobility RAZR V3
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
133 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
