My dvd player will not record or play any discs
  • 6,784 Answers
HI, this will happen when the optical lens assembly has failed. this assembly is responsible for the lens function and, tracking of the lens as well. replacing this part will restore your unit.
Posted on Jul 11, 2009
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Feb 11, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
Which recordable dvds play on this dvd player
this brand and model should be able to play the discs you mentioned witih no problems, unless it is defective, or a error is being made when you are recording the discs. If you are recording and they ar enot playing, most likely you are not "finalizing" the discs durring the burn processs. All discs MUST BE finalized to be played on any dvd player.
Feb 08, 2010 | Teac DV-3500 DVD Player
Won't play recorded DVD's - states check disc
Depending on your player model, a few things could be going on:
1. The DVD you are recording to is incompatible with your Go Video player. Check your manual for DVD playback compatibility (DVD+R, DVD-R, DVDRW)
2. Your Go Video player has a laser alignment problem. If it plays other DVDs, yours is most likely the first solution.
May 02, 2009 | Televison & Video
Recorded DVD will not play in another player
try playing on computer. if ok copy on hard drive and burn it. if it wont work on your computer. there was an error in the making of the disk..
Apr 15, 2009 | Televison & Video
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
Recorded dvd will not play
You have to finalize the disc. Get out of disc menu and press setup on remote. Select disc edit and finalize then it will play on other dvd players.
Aug 15, 2008 | Philips Magnavox MWR10D6 DVD Recorder
I used my pd-dvr100 to record a copy of a home made dvd. I do not know the format of the source disc. The process went well. The PD-DVD100 WILL PLAY THE DISC. However, the disc will not play on the player...
Have you tried to make sure the disc is finalized. Second check the manufacture website to make sure that the dvd player you are trying to play it in is compatible with the disc type that you recored on. Veryfy this by looking at the disc type on the dvd commonly refered to as +R or -R
Mar 08, 2008 | Protron PD-DVR100 DVD Recorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
