Question about Acoustic Research AW-711 Headphones
Power button not working
I cna't get the power button to come back on after changing batteries. I have tried rechargeable and disposable batteries.
0 characters
1 Points
My Audio headset has worked great-but stopped working
Could be the battery has a weak charge! Try running the battery completely flat, recharge fully, then run completely flat, and repeat this cycle about 3 times......This will give the rechargeable battery a revitalised full charge! This is a good procedure for any rechargeable battery as part charging and charging when not completely flat does take its toll on a battery.
Nov 12, 2015 | AUVIO Bluetooth Headphones
After working correctly for months, my wireless headphone stopped transmitting anything -- not even static
It could be that the rechargeable battery has failed. Take the batteries out and then replace them. Perhaps this may help you:
Go to this site and it will automatically download the PDF file to your computer. Takes about 3 minutes. Go to Start> Documents> Downloads to find the PDF file RS170_US_INT.
Feb 05, 2015 | Sennheiser Headphones
How do I get sound to my Sennheiser RS120 wireless headphones when it shows as working properly?
Dirty volume control on headphones. Try moving the volume control back and forth several times to clean off the contacts.
Dec 14, 2014 | Sennheiser RS 120 Consumer Headphones
My x32 turtle beach headset has no power
Batteries are probably dead, order a new set or try using disposable ones
Apr 23, 2012 | Voyetra Turtle Beach Ear Force X3 Wireless...
Have replaced the headphones with alkaline non-rechargeable batteries and can get the power light on the headset to only light up when it is actually plugged into the stand. Otherwise the power will not...
Have you made sure to replace the batteries with the right kind? Placing non-rechargeable batteries in a charger may damage both the product or the batteries themselves. It may also be that the batteries are dead. If you are adamant about using alkaline, try replacing with a fresh set.
May 03, 2011 | Acoustic Research Headphones
The operating instructions say that after 16 hours the red power/charge indicator light would go out, indicating the batteries are fully charged. After 3 days the red light on my unit is still on. The...
I have the MDR-RF970R but I bet the battery is the same. If you have had the headphone for seceral years then I bet you are right, the battery is going. You might try using them till the battery dies and then recharge. This is called deep cycle and may time it will extend the life of rechargables.
If the headphones are new, then just check and make sure that they going all the way into the charge slot.
I will say it is not common for me to see the light off, but I use the headphones all the time.
Good luck.
Apr 30, 2010 | Sony MDR-RF970RK Headphones
Batteries for Philips wireless headphones
Actually, look at the Philips SBC HB550S battery, the black label on battery isn't going to the end of the battery's "-" side, there's few millimetres of solid metal. Look at other, ordinary rechargeable battery, for ex duracell's. This other battery has label all over battery (from "+" to "-"). So only thing you have to do to make any batteries work with you have to cut and remove this label from battery you want to use from the "-" side of the battery, about 1-2 cm, like philips one has. It's because these headphones have this extra clip in battery sockets, philips wants us, customers, to buy those extra-expensive batteries. That's as simple as it is! Hope it helps you, it definitely helped me.
Apr 04, 2009 | Philips (33-01-031) Headphones
RCA headphones - nicad or alkaline batteries WHP141
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Sennheiser TR136 Wireless Headphones Nothing Happens
I had a similar problem - after owning them for 4+ years, no sound we coming out, and no beeps -- nothing. The lights on the charger stand were on though.
I tried buying new rechargable AAA batteries and they were NIMH (nickel metalhydride?) and still didnt work. I borrowed a friend's pair of NICM (nickel cadmium?) AAA rechargables though and the problem was solved!
So, it would seem the some of the new chargable battery types might not work in older models of this unit (which is also called the RS 130 now in the US and Cdn web sites).
Hope this helps!
Mar 29, 2008 | Sennheiser HDR 120 Consumer Headphones
Replace the NiMh batteries. They might be bad. Could happen during power surges as you indicated you had. Let them charge up fully 14-18 hours as the book suggests.
Aug 25, 2007 | Sennheiser RS115 Wireless Headphones
Acoustic Research AW-711 Headphones Logo
26 people viewed this question
Top Acoustic Research Headphones Experts
Owen Barnes
Are you an Acoustic Research Headphone Expert? Answer questions, earn points and help others
