The blower resistor in a Toyota Townace Noah with a 3S engine is typically located near the blower motor, which is responsible for directing air into the vehicle's cabin.
Here is a general guide on how to locate the blower resistor in a Toyota Townace Noah with a 3S engine:
Locate the blower motor: The blower motor is typically located under the passenger side dashboard, near the footwell.
Identify the blower resistor: The blower resistor is typically a small rectangular or cylindrical component that is connected to the wiring harness near the blower motor.
Remove the blower resistor: To access the blower resistor, you may need to remove the cover or the panel that covers the blower motor. You can then unplug the wiring harness and remove the mounting bolts to remove the blower resistor.
Note: The location and accessibility of the blower resistor may vary depending on the specific model and year of your Toyota Townace Noah with a 3S engine. If you are unsure about the location or how to access the blower resistor, it is recommended to consult a professional mechanic or the vehicle's owner's manual.
It is important to handle the blower resistor with care, as it can be easily damaged if not handled properly. If you are not confident in your ability to replace the blower resistor, it is best to seek assistance from a qualified mechanic.
If you have a manual system, you have a resistor. If electronic, you have a blower motor speed controller. Please rate if this helps.
here is info:
Control System Outputs-Manual A/C Blower Motor Switch Resistor
The heater blower motor switch resistor has the following features:
The assembly is located on the evaporator housing in the engine compartment.
Three resistance elements are mounted on the resistor board to provide four blower motor speeds.
Depending on the heater blower motor switch position, series resistance is added or bypassed in the blower motor circuit to decrease or increase blower motor speed.
An overheating protective device (thermal limiter) will open the resistor coil circuit when the temperature reaches 121°C (250°F) interrupting the blower motor operation in all speeds except HI.
The thermal limiter cannot be reset and is not serviceable.
Control System Outputs-EATC Blower Motor Speed Control
The blower speed control is located on the evaporator housing in the engine compartment.
The function of the blower motor speed control is to convert low power signals from the electronic automatic temperature control module to a high current, variable ground feed for the blower motor (18527).
The blower motor speed is infinitely variable and is controlled by the electronic automatic temperature control module software.
A delay function provides a gradual increase or decrease in blower motor speed under all conditions.
The resistor is located under the hood on the passenger side. At the
back of the engine compartment you need to locate the airbox it can be
identified by a circular piece that's right beside the fender on the
firewall (this is your blower motor) to the right if it (looking from
the front of the truck) about 4 -6" you will see a wire plug. Unplug
this connector and locate the four screws that attach it to the air box.
Remove these screws and pull the resistor from the housing.
this is for manual heater system. If you have electronic (digital display) you don't have one. Instead you have a blower motor speed controller.
here is info
Control System Outputs—Manual A/C Blower Motor Switch Resistor
The assembly is located in the engine compartment on the evaporator housing toward the center of the vehicle.
Three resistor elements are mounted on the resistor board to provide four blower motor speeds.
Depending on the heater blower motor switch position, series resistance is added or bypassed in the A/C blower motor circuit to decrease or increase A/C blower motor speed.
An overheating protective device (thermal limiter) will open the resistor coil when the temperature reaches 121°C (250°F) interrupting the blower motor operation in all speeds except HI.
If the blower moter only works on hi speed it is the blower motor resistor that is bad. The blower motor resistor is located under the passenger side of the dash next to the blower motor. It is not necessary to remove the blower motor to change the resistor.
