Question about Onkyo TX-NR801 Receiver
Onkyo tx-nr801 net tune setup help
I need help setting up my net tune. My receiver wont talk with my network. Please help. Thanks
Bryan
Below is the sequence that I made it work
1. download the latest firmware for tx-nr801 and net-tune central software at Onkyo website as shown below:
http://www.intl.onkyo.com/products/net-tune/download/index.html
Click on "User Identification" at the bottom
(You'll need the serial number shown at the back of TX-NR801
to download it)
2. disable firewall in your PC or notebook and start
updating the firmware for tx-nr801
If firewall can't be disable, you probably can't go through this.
This step takes about 30 min.
(There is a document showing how to do this with the download)
3. keep disabling firewall in your PC (notebook) and install net-tune central (there is similar document describing the procedure too)
4. By pressing Net-Audio on remote controller (it can switch between mServer and iRadio fucntions if you keep pressing this button)
Posted on Nov 30, 2007
I need hdmi with ARC to go to Tv. This amp has no hdmi what converter or ??? do I use.
Hello Arthur, This unit does not have ARC because just as you said it does not have HDMI. Your only option is to use an optical cable from the TV to the receiver. Thanks, FJD
Mar 27, 2016 | Onkyo TX-NR801 Receiver
Onkyo TX-NR801
is the mute indicater displated on the screen.
Jul 12, 2008 | Onkyo TX-NR801 Receiver
What are the advantages to doing a factory reset? I'am setting up tx in new place and need to start fresh. Does the tx reset?
Hello Arthur, The reset will take all of the settings back to factory default. This includes network settings and speaker settings. Thanks, FJD
Were do I plug my wireless headphones? Dos this txnr801 have on tv screen capabilities? If so how do I hook it up?
RTFM which is available for free at retrevo.com after you register.
http://www.retrevo.com/support/Onkyo-TX-NR801-Receivers-manual/id/365dj196/t/2/
As far as the unidientified earphones go, well, it has a manual too somewhere
Jun 23, 2011 | Onkyo TX-NR801 Receiver
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
8omh reciever and 6omh speaker
HI,in the speaker set up menu on your amp there should be a 6ohm setting but if not don,t worry as it won,t cause any problems.You will have to set the levels for your speakers so they match each other to keep sound right.
HOPE THIS HELPS.
CABLE GUY.
Aug 03, 2008 | Onkyo TX-NR801 Receiver
TX-NR801 panel connection
Basic handtools should be available, as well as having soldering tools. No, I'm sorry, there are no schematics or drawings that show what and where the parts are due to the same cabinet being used for several different models and power ratings. Go ahead and spring for the tech info from the MFGR. Common sense and some mechanical aptitude would be what you need for a clean R&R.(removal and replacement)...accordianman
Apr 30, 2008 | Onkyo TX-NR801 Receiver
Gold version Onkyo Tx875 amp
What country did these units come from? Video specs are different in various places in the world. NZ uses a format called "PAL", then there is "SECAM", used in some parts of Europe, (most notably France) and then there is NTSC, used in Japan, US and S. Aisia. Also, I need to know you video source and format...accordianman
Jan 15, 2008 | Onkyo TX-NR801 Receiver
Onkyo TX-NR801
Are you in "sleep" mode. This dims the display...accordianman
Oct 30, 2007 | Onkyo TX-NR801 Receiver
Rear left channel not working on Onkyo NR801
Sounds as if it's time for a shop visit, unless you want to try this yourself. The panel connection on the rear of the receiver, or the protection relay have apparently come loose from the circuit board. It happens sometimes when stress causes the cabling to pull on the back of the unit..accordianman
Feb 16, 2007 | Onkyo TX-NR801 Receiver
Onkyo TX-NR801 Receiver Logo
1,344 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
