? 2:43
https://www.youtube.com/watch?v=Mmvr4Xn2W1w
Jun 17, 2012 - Uploaded by Kenneth Watt
For more washing machine help please see our website at ... Far more helpful than the wretched manual that came with ourwashing machine. :) ... I just did this to my washing machine, the filter was blocked up with wool, ...
manual stays with washer. Contents. Important ... Keep this manual and your sales receipt together in a safe place for ... Amana Appliances offers long-term.
Oct 13, 2011 - Do you have a front load clothes washing machine? Have you every wondered what happens to that spare change you occasionally forget to ...
Filter is at rear of washer.
Remove lower rear panel.
Remove large black hose from bottom of drum.
Remove and clean filter inside hose.
Refit and test.
The filter is located at the rear of the washer.
Remove the lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Refit and test.
mam
there is a filter it will be blocked please clear it then see its draining also check if there is drain pump if its there it should work.drain pump is located at the back of the machine and the filter at front of the machine.
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
check that the outflow pipe is not blocked. Turn off power supply get a bucket ready, disconnect the outflow pipe from the u-bend under the sink and check that it is not blocked.
two possible cause. 1)drain pump motor faulty.
2)some thing struk inside the pump.
it easy to locate the pump ,normally at the bottom near the draining pipe .hope it help
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one:
You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump.
If the drain pump does not come on, you may have a pump failure.
In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
not a fault with washer. i guess you are plumbed into trap under sink. the spigot you fastened drain hose to is blanked off - there are various methods of doing this including have to saw off the end of the spigot with the bread knife. possible also a fault with pump or filter
