Question about HP Deskjet D4160 InkJet Photo Printer
How to dislodge a paper jam
  • 130 Answers
Turn off your printer.
Carefully pull out the paper.
And run the printer.
Posted on Jul 14, 2009
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
Sep 04, 2014 | Lexmark E Office Equipment & Supplies
Canon IR8070 paper jam infront of Registration roller
If you can reach the paper in the jam you will have to pull it out to dislodge the jam. Be careful not to rip the paper in doing so!
Aug 28, 2014 | Canon Office Equipment & Supplies
How to disassemble a Epson RX430? Have tried it for hours. The reason that i wanted to take it apart is to check if there are any bits of paper stuck inside as i keep on getting the paper jam error even...
Remove all paper and toner. remove paper tray any other loose items. Use a shop vac as a blower and try to dislodge any loose bits of paper. What is more likely is that a small plastic arm that senses for a paper jam has been dislodged.
Dec 31, 2017 | Office Equipment & Supplies
Jam in bin
this is a common fault. look where the paper was jammed, you may need a torch. There is a black or white sensor there that has been dislodged. Once clipped back into place it will then report to the printer that the paper path is clear and no longer a jam.
Oct 05, 2009 | HP Color LaserJet 2600n Printer
False jamming at duplex unit
Sounds to me like a paper jam switch has either become dislodged, or malfunctioned...you'll need a tech.
Feb 21, 2009 | Canon NP 6050 Copier
Pixma mp750
it seems the lever for the paper jam is having problem you have to open the printer and check for any broken or dislodge part.
Aug 18, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Paper jam
you have to open the printer and check for any broken or dislodge part in there.
Jun 30, 2008 | Brother DCP 130C All-In-One InkJet Printer
Papaerjam lite stays on, no paper jam
It is possible that there may still be a small piece of paper blocking or lodged in the exit sensor area. It is also possible that when removing the jammed paper that the sensor arm became dislodged and thus creating a false jam code.
Jun 25, 2008 | Sharp AL-1641CS All-In-One Laser Printer
I have a Panasonic Workio DPCL21 color laser printer with "Jam 1"
If no paper can be found, most likely a stuck lever in the paper path. Sensor lever may have been dislodged during a jam removal.
Dec 03, 2007 | Panasonic Workio DP-2330 Printer
HP Deskjet D4160 InkJet Photo Printer Logo
83 people viewed this question
Clive
Clive
