Question about Logitech Z-5500 Computer Speakers
When I change the fuse in the z-5500 it
My Z-5500 has ceased working. It appears the subwoofer is not functioning properly beacuse the fuse blew up apparently through a voltage upsurge. When I change the fuse in the subwoofer it immediately blows ouit again.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 231 Answers
At this point your hands are tied to fix these due to a capacitor failure or whatever. you can try wrapping the fuse in aluminum foil but this may cause even further problems but i have seen it work before. be sure to keep a close eye on these if this works because the fuse is ultimately a safety device.
Posted on Jul 24, 2009
So after getting my car back for the garage my subwoofer isn't working I checked to make sure all of the connections are correct and the settings are there why won't it work
Check to see if your amp is on. You may have blown a fuse somewhere maybe on your amp. Check for proper voltages and make sure the sub isn't blown by pushing on it. If you feel unequal resistance, you probably blew it. Also check the ohms on the woofer.
Jun 06, 2011 | Car Audio & Video
Blown fuse on mine. replaced it and it blew again instantly upon power up. meter shows 7 amps flowing through fuse holder and this is only a 2 amp fuse. What else in the circuit would be causing it to draw...
We are talking about a subwoofer? Two causes. The Power supply and the Amp section. First power -transformer, rectifier, voltage regulator, big capacitors. Amp section whatever does all the work, often on a heat sink, most likely cause too!
Dec 12, 2009 | Audio Players & Recorders
My SW 22HT Kenwood subwoofer stopped working.The fuse was bad it was replaced and the new fuse blew again
The reason the fuse blew again is that an overload has occured. It could be a faulty part in either the power supply section, or the amp section. Follow the curcuit from the fuse, be on the look out for damaged, burnt parts, suspect anything on a heat sink.
Nov 30, 2009 | Audio Players & Recorders
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
Fuse blows when powered on . KLH E-10DAW
Hi, you can get the fuse at Polk Audio. 800-377-7655. You can talk to technical, too.
Jan 20, 2009 | KLH Audio Players & Recorders
No power in Z-5500 logitech speakers
The logitech z 5500 digital is very sensitive to power peaks. One of the most know problems is that the fuse breaks because of these peaks. I´ll show you how to replace the system´s fuse.
First of all, you just need to write down the specification of the system´s fuse. The system´s fuse specifications are printed in the back side of your subwoofer, right next to the subwoofer´s on/off switch. In an european system it says: "T2AH250V (Time Delayed)". If you use another power voltage (120v), it may say something different. Anyway, write it down on a piece of paper and go to an electricity store and ask for a similar fuse (It is very cheap. Not more than 1$)
-The best way to get a similar fuse would be by bringing the broken fuse with yourself to the store-
In the back of your subwoofer, using an screw-driver, un-screw the fuse´s cover and remove the broken fuse. Replace it with the new fuse, attatch it to the cover and screw it back again.
If you turn on your system now, it will probably work fine.
Oct 20, 2008 | Logitech Z-5500 Computer Speakers
Car audio
Does it blow the fuse if you disconnect the RCA cables and disconnect the speaker wires from the speaker terminals of the amp?
Does it only blow the fuse after the head unit is switched on (only after remote voltage is applied to the amp)?
Apr 28, 2008 | Car Audio & Video
Logitech Z-5500 Computer Speakers Logo
593 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
