I cannot access my 1.1 memory stick as I did befoe I reloaded an ole DELL MMX200 with Windows 98. I can use the ports for a scanner as I did before so I know the ports work
    Problem Solver:
  • 5 Answers
If you are using usb ports, some devices need a highspeed 2.0 usb port to work properly.
a pci card with usb 2.O can be added for about
$10
Posted on Jul 11, 2009
I OWN A DELL INSPRION 7500 PENTIUM 3 !! I PEUT A VERBATIUM 8GB MEMORY STICK IN IT & I GOT AN ERROR MESSAGE THAT SAYS IT DOES NOT RECONIZE IT !! WHAT SHOULD I DO !! DO I NEED A NEW MEMORY STICK DRIVER...
if you are running windows 98 then you should consider in upgradeing to xp if you are all ready running xp and you still get the message then the usb stick may be faulty
Feb 20, 2011 | Dell Inspiron 7500 Notebook
Not detected
1stly try the Kingstone in another PC - if it works in another PC you have 1 of 4 problems:
1] You are using a very old version of Windows and therefore would require drivers for the memory stick. (i.e. Windows 95 or Windows 98)
2] Your USB ports are faulty - try the ports at the back of the PC instead of the ones in the front if you have not done so already
3] There is a virus on your memory stick and it is attempting to load an executable file when u plug it in and that is causing it to fail.
4] It is detecting fine but you cant read it because the FAT (File allocation table) is damaged in which case it will need to be formatted.
I will need some more info though - for example:
Does windows say "Hardware detected" when u plug it in?
Are you getting any lights flashing on the memory stick?
What do you see when u click on my computer? Does is show up at all but u just cant open it?
Good Luck
Feb 04, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to transfer pictures from computer to camera memory card?
Below is how to transfer your photos incomputer to a memory stick in Windows XP operating system 1. Insert the memory stick into a compatiblememory stick reader. Plug the memory stick reader, with the memory stickinserted into it, into the computer's USB port. 2. After a moment, a screen thatsays "Removable Disk" will pop up and prompt you to take an action.Click on "Open folder to view files using Windows Explorer." Thiswill open the folders on the memory stick. Select and open the folder whereyour photos are stored. 3. With the memory stick folderand the photo folder open simultaneously, use the mouse to click-and-drag thephotos to the memory stick folder. 4. Close all folders and removethe memory stick reader from the USB port. 5. To ensure that your photos havebeen transferred, plug the memory stick back into the USB port. When the"Removable Disk" screen pops up, select "Open folder to viewfiles using Windows Explorer." Once you see the photos on the memory stickfolder, you can close the folder and remove the memory stick reader from theUSB port.
Jan 08, 2011 | Fuji FinePix J10 Digital Camera
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
Dell D531 crashes on startup
This could be a software problem, or hardware. You need to determine which. I usually suggest troubleshooting memory first, but the D531 has memory under the keyboard, so in this case try booting from any bootable disk and see if the PC stays up. I like to use Ubuntu Live for my tests. You can get it here:
https://help.ubuntu.com/community/LiveCD
If that is stable, then your problem is probably in Windows and you will need to reload from disk. Make sure you backup any files first.
If your PC crashes off of the LiveCD, pull out half of your memory and try again. Next, try the other memory. The second stick of memory is under the keyboard. This assumes you have two sticks. Directions for removing memory can be found here.
Feb 15, 2010 | Dell Latitude D531 Laptop Motherboard ...
I NEED A DRIVER FOR A KINGSTONDATA TRAVELER MEMORY STICK ON THE USB PORT. IM RUNNING A SPECIAL SEWING MACHINE APPLICATIO ON WINDOWS 98 BUT THE USB PORT DOES NOT SEE THE MEMORY STICK. Motherboard Compact MS...
Unfortunately, there are no drivers available for windows 98. Most of your memory sticks will not work on windows 98. Your best bet is to burn your files on a CD and use that instead.
Jun 11, 2009 | Compaq Evo N610C Notebook
My windows 98 dell dimension 7500cx will not recognize my verbatim 256 mb memory stick
windows 98 need special driver from usb memory stick manufacturer.
if they dont have it then its not a compatible model for win 9x.
what i have done in prior is if high speed internet is saving it to online drive storage free website like xdrive.com if u have aim account youre ready to use it or others like yahoo mail yourself the files then retrieve in other pc.
Jul 30, 2008 | Electronics - Others
USB
is it a desktop or laptop, you can go to your device Manager, check if the drivers are loaded properly,and reload or you can just run the last win98 patch its sure to work
Dec 05, 2007 | Microsoft Windows 98 for PC
Downloading software (Twain??)
The download website for your scanner is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8008
A TWAIN driver is simply a generic scanner software driver that your specific Canon software can hook into and use.
I recommend starting with this one and see if it installs the TWAIN driver you need:
"CanoScan Toolbox v2.2.3 for Windows 98/Me/2000/XP"
Nov 18, 2007 | Canon CanoScan N656U Flatbed Scanner
Computers & Internet Logo
Alun Cox
David Payne
David Payne
