Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
My B & S fouls plugs, runs rough, almost stalls when blade
Engaged. Really uses gas. Put new plugs in less than 5 hours ago. Fresh gas, so minimal crud in tank. What's the deal???
  • 582 Answers
THE PROBLEM SOUNDS LIKE THE CARB IS RUNNING TO RICH OR TO MUCH GAS IS BEING PUMPED INTO THE CYLINDER. IS THERE ANY SMOKE AND WHAT COLOR SMOKE
Posted on Aug 10, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I recently replaced a cool pack on my 2001 dodge Durango now it is running really rough and it keeps dying and getting hot any suggestions?
The problem you describe is likely unrelated to the new coil pack. Rough running and stalling can be indicative of a fuel delivery problem, contaminated fuel, or one or more bad spark plug wires (or fouled spark plugs, but less likely). Readout all stored codes from the ECU using an ODB reader for a diagnostic starting point.
May 14, 2015 | Dodge Cars & Trucks
Failed emissions hc high
First I recommend changing spark plugs, air filter, and change the oil & filter. If these are dirty or fouled up it will kill your millage and help to fail smog.
You can reduce both NOX and CO emmissions by adding denatured alcohol to the gas tank. Run it down to a bit under 1/4 tank and add 1 1/2 gallons. It makes the engine run a bit rough, but really clean.
If you still fgail SMOG then you need a new catalytic converter.
I used to "trick" my 86' with alcohol, but just rebuilt the engine so I put a new Cat on it. It passed emissions with WELL BELLOW numbers.
Good luck.
Aug 08, 2014 | 1991 Toyota Pickup
Generator trouble starting and running rough
ok simple things first, new spark plug, fresh gas, a decent dose of fuel cleaner a bottle doses 12 gallons so say if 3 gallons gas use 1/4 bottle (yes double dose wont hurt) , air filter, try running this first and see if it picks up over time, the methanol gas really crude's up small engines and the cleaner will hopefully clear it up, use fuel stabilizer with ethanol protection and dont let tank sit empty always full to keep moisture to lowest level. if this doesnt work then likely carb is fouled and needs rebuild
Jun 03, 2012 | Hammering
The blades will not engage when the knob is pulled....toro 50
.... burning rubber smell? Sound like you have done a cutter belt.
May 27, 2012 | Toro Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Driving 60mph power drops as though out of gas. Coast 2-300 yds pump gas pedal van back to normal. Now at home it starts then stalls, will only run 5-10 seconds. New plugs&wires distributor cap and...
signs of a bad fuel pressure regulator. the vehicle runs rough, the engine will not start usually in the mornings. many times engine starts but stalls shortly after starting. a bad regulator can result in fouled plugs. black soot on plugs, blake smoke from tailpipe, running rough, stalling. you could have residue in fuel tank and need to change fuel filter again. have a very good day !!
Mar 09, 2011 | Volkswagen Eurovan Cars & Trucks
Briggs & Stratton 60200 series engine intake valve tar
I'm having the exact same problem with a Briggs & Stratton 80202 engine on my Mclane reel mower. I cleaned out the valves and cylinder head, put it back together and it runs nicely. I ran it for about a half hour then turned it off to adjust the blade. A couple hours later I went to start it and no compression. The Intake valve is stuck open with gum from running it for a half hour! The can of gas I have is less than a month old. I'm going to try a different brand of gas.
Jan 09, 2010 | Garden
My weedeater brand trimmer won't start
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
Aug 28, 2009 | Craftsman 25cc Gas Line Trimmer
Rough running/Stalling
you need to check your fuel pressure
Jan 02, 2009 | 2000 Lincoln LS
1995 Alitma ran rough and stalled
Its just fouled some plugs again. Need an overhaul. If you just put a valve job on it it will just put more stress on the rings and will need it anyway. Not much you can do except change plugs all the time!
God Bless Greg
Dec 06, 2008 | 1995 Nissan Altima
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
618 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
