Question about Xerox Phaser 6100/BD Laser Printer
Xerox workcentre xd 100 paper gets jams just before intering fuser
Jamgoing into fusers before
    Novelist:
  • 208 Answers
On the XD 100 if it is jamming when it is just entering the fuser, check the gear on the end of the heat roll.
Those frequently crack and or flat out break off.
That gear is easily replaced and inexpensive. If you require information where to purchase one, let me know via a message here.
I checked and you can purchase that gear for $14 or less.
Posted on Dec 03, 2007
Xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Jul 19, 2010 | Xerox WorkCentre M15i Laser Printer
Paper jam in a Xerox Comy Centre C20
A couple of things.
There is a bushing at the front of the exit transport that fall out of the frame. That requires removing the scanner and looking in the exit transport that way.
You may also have something stuck in that transport. Take the fuser back out and then take a minella folder and push it through from above the fuser to the output area and see if it disloges anything. If not, then you have to pull the scanner off and look in that exit transport area for problems.
Jun 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox M15i paper gets jammed above the fuser "paper jam 2" fuser is hot but i think its supposed to be. Almost every sheet gets jammed.
Yes it is supposed to be hot. Let is sit off for an hour.
Open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
Sep 29, 2009 | Xerox WorkCentre M15i Laser Printer
I have a paper jam on the right side of my Xerox WorkCentre xd100. I can't find my User's Guide, and don't know how to release the paper jam.
If the paper is in the fuser area, the fuser needs to be taken out.
I have heard and seen some customers take out the fuser. It has two wood screws to be removed and the plug on the side.
Extra care needs to be taken when doing this task.
Unplug the machine.
remove the two screws and unplug the fuser plug.
Gentley pull out the fuser and you can see the paper in the fuser.
There are small stripper fingers down there, be very careful when taking partial pieces out, be very patient, and extra careful.
This roller does not turn very easy if you need to rotate it.
To reassemble, DO NOT OVER TIGHTEN THESE TWO SCREWS!!!"
Just tighten snugger than snug tight. Which means a loose tight. The mounting walls can break very easy.
If the problem jam is below by the tray, try to manage to push a card stock from below to get out the paper.
Let me know if this works.
Good luck.
Sep 09, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Workcentre 24- Paper jam in the fuser
Shut down. Unplug!!! Remove fuser to remove jam. Fuser may be or be going bad.
Apr 22, 2009 | Xerox WorkCentre M-24 Color Copier
Clicking sound and crumpled paper
Bad heat roll drive gear in the fuser. Very common problem.
Look up on google a business called "The Parts Drop". Ask for Britt, part is $13 or $14.
Aug 31, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
ERROR E2
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
May 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox 416 Fuser
Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
Jan 25, 2008 | Office Equipment & Supplies
Xerox Phaser 6100/BD Laser Printer Logo
126 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
