Question about Sanyo DS31520 31" TV
My 2005 Model HT32744 Sanyo has cracking thunderus sounds periodically expecially in afternoon and early evening. Then works well until another time. Have had cable problems corrected by comcast before. Could this be a cable problem?
    Problem Solver:
  • 15 Answers
To check if its cable or circuit failure,try to fed your TV with audio from a dvd or cd player and observe it for a long time.If the still the problem occurs then the problem is in the your TV circuit.If not the problem is in your cable connection.
Posted on Jul 13, 2009
I have a Crossfire 2005 (base model) with 31k miles that has had the issue with stalling after running for a while. I replaced the crankshaft position sensor but after a couple weeks of running fine the...
I have a 2005 crossfire as well and it did the exact thing. Finally took it to a Mercedes shop and they found one of the crystals were cracked on my rely, it sits under the hood on the side of the wheel well. It's a black box. The only way they found the cracked crystal was with a magnifier glass. Not cheap by the way, but have had no further problems since that was done..
Oct 23, 2013 | 2005 Chrysler Crossfire
Using a Radio Shack 2 in 1 Ultra- Slim Universal Remote on a Sanyo HT32744 TV but it does not allow me to acces the Menu. (1) Will this remote work with this modle of TV? (2) If YES, what code do I use?
Since the Radio Shack remote doesn't have a menu button, I'm not surprised you can't acess the menus with it. The only Sanyo codes are
Sanyo 0154, 0159 (for TV only units)
This remote was only designed to duplicate the most
common functions of the original (power, channel
changes and volume changes).
You can get a replacement of your original remote from remotes.com
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12758464711170&smodel=HT32744&brand_pn=SANYO_HT32744
I hope this helps.
Jun 06, 2010 | Sanyo HT32744 32" TV
Sanyo tv model st-21cf1 no sound
KElvin Dacasi kapag maliit ang tao nsa screen tapos nasa ibabaw pa,Palitan mo ng bago yung mga Capacitor malapit diyan sa Vertical IC,mura lang yan!!!
Apr 06, 2010 | Sanyo HT32744 32" TV
I can't get sound from my speakers on my Sanyo HT32744 tv but I can get sound from surround sound speakers through surround amplifier.
Most tv's have a way to turn off the speakers. Either a button on the remote, or in the menu. Go into the menu, sound options. See if it says speakers on/off.
Oct 27, 2009 | Sanyo HT32744 32" TV
Model #
The solder joints on the CRT board might have cracked and cause this symptom. What you are describing indicates that the red gun is intermitten, and the solder joints on the CRT socket itself (red cathode) or the red output transistor have probably cracked loose.
Aug 23, 2008 | Sanyo HT32744 32" TV
Sanyo TV - HT32744
Lower the contrast first.
If colors not in balance, reduce saturation until "normal" to your eye with whichever color (or color pair) out of balance.
Aug 19, 2008 | Sanyo HT32744 32" TV
TV problem
Sound like either the Red or Blue driver transistor on the CRT board is intermittant.
Hope that helps...
Geno
Apr 03, 2008 | Televison & Video
Sanyo HT32744 Picture mostly green and blue
On mine I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
Jun 22, 2007 | Sanyo HT32744 32" TV
Sanyo DS31520 31" TV Logo
44 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
